Author Topic: Testing Tantalum caps  (Read 3729 times)
Offline johndon2000Topic starter
« on: June 21, 2013, 10:50:43 am »
On a previous post someone mentioned that Tantalum Caps have high failure rates and are a good point to start when faulty finding... if a board has 40+ tantalum caps is there an easier method of testing the caps other than taking them all off 1 by 1 and measuring capacitance?!
Offline Neilm
Re: Testing Tantalum caps
« Reply #1 on: June 21, 2013, 12:57:25 pm »
The first time I had a tantalum cap fail it was obvious - the smoke, small flame and discolouration were a bit of a give away. The second time it had failed short circuit - so I just pushed lots of current through the voltage rail until I had the same give away as the first time. :D
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline 807
« Reply #2 on: June 21, 2013, 01:16:00 pm »
Like Neilm, in my experience I've only come across faulty tantalums that have either exploded, or have gone short circuit.
Trying to find a S/C on the power rail of a piece of 70's - 80's test gear containing loads of tantalm decouplers without a ToneOhm can be quite difficult.
Online KD0CAC John
« Reply #3 on: June 21, 2013, 02:07:49 pm »
Just guessing here , but looking for shorted tal-caps .
Couldn't you just run not more than the rated current for the circuit in question and just measure excess heat ?
My idea being not to damage the device under test .
vlf3
  • Guest
« Reply #4 on: June 21, 2013, 02:19:03 pm »
From my experience the only way to be sure, is to lift one leg out of circuit, and ESR the little bugger... otherwise it's down to leaky or short.  :-\
Offline vk6zgo
« Reply #5 on: June 22, 2013, 03:40:34 am »
Remove 'em all!
Once you've done that,there's no point testing them--just replace the lot!
Of course,that's how you would do it if you are doing it to earn a crust---man-hours cost a lot more than Tants! ;D
A hobbyist may have other priorities!
Offline peter.mitchell
« Reply #6 on: June 22, 2013, 05:04:53 pm »
Remove 'em all!
Nah, just replace em all, stuff em'. Small Alu 'lytics are cheap as chips.
Offline Neilm
« Reply #7 on: June 22, 2013, 05:34:40 pm »
Remove 'em all!
But they don't have as good a frequency response - so if doing that add some small ceramics in parallel.
Neil
