I'm trying to build a small MIDI synth box as a project, based around the Aides eVY1 module.
I built a small test rig connecting the outputs the manufacturer claims to be "headphone out" to the line in of my amp, but the sound is very quiet with more power supply noise than actual music, and that is with the amp dial turned up to the max and MIDI volume on the max too. "Speaker out" of the module is not an option, since it's designed for actual speakers with a Class D amp inside it (I think — the tiny-chip-that-outputs-PWMish-stuff kind of thing).
Measuring with my scope I got around 0.7-0.8Vpp out of it, even though I always thought 0dBV is 0.775V apparently that is not enough — and reading up the specs on the Line Level suggests I need to go to around 1.6Vpp for +4dbU.
For that I chose to use a TL072 opamp configured for 2x gain. However, the synth isn't going to have bipolar power, so I have to make do with +5V and GND only.
Reading up on OpAmps and all I eventually came up with the following output stage, rightmost section:
U7 is the TL072, +Vcc is to 5V, -Vcc to Gnd.
Then pairs of R16/R17 and R18/R19 are used as voltage dividers to set the positive inputs to 2.5V — the midpoint between the +Vcc and -Vcc rails of the opamp.
C3 and C4 are blocking that voltage from going back into EVY_HPL/HPR which are my 0.7Vpp outputs from the generator chip.
Am I correct in this schematic and would it produce the desired 1.6Vpp output?
(If so, would I need some super precise resistors for the dividers?)
Thanks!
