Merci, Jon. I have read the datasheet for the ADC and even in the typical implementation it has a low pass filter for anti alias. This is what I meant when I said that it had to have a filter. Going by the SRS760 manual, it seems like I should have -96dB at approximately 200kHz. With respect to ENOB and noise/THD, I have read on the subject today and talked to my teacher about it. I think that I will "sacrifice" some of the ADC bits in order to facilitate or improve other areas of the design, and I will target the ADC outputting 24 bit data that is only accurate to 18 bits. If I did not understand incorrectly, that is what is implied in the application note that Terry Bites provided below.
Thank you very much Terry. I found the application note that you provided extremely insightful, I even read it over with a teacher to understand the provided example (that I found to be a little unrelated to the rest of the document). I arrived at the end, after filtering the op amps using the methodology described in the document, with the same opamp that you suggested and that is on the implementation on the ADC datasheet, the THS4551. As for impedance matching, I was planning to compensate the ADC series resistance and parasitic capacitance using this method:
As for the FFT analyzer, it is the equipment I have at my lab, and I found that the manual is very insightful at describing a typical analog signal chain. Obviously reproducing all those relay-set gain stages is impractical for the scope of my project and the level of my habilities, but it is a nice reference. My plan is to have the input amplifier have a fixed 20dB gain and have the attenuators be selected manually like in the attatched picture
. I plan on changing the values for the attenuators so that they have values from 0 to 40dB in 4 dB increments which will hopefully net me a -20dB to 20dB gain/attenuation from the input to the ADC.
As for The Art of Electronics, I actually own a physical copy of the third edition, it has helped with a bunch of different classes, but with the advent of the internet and stuff like that, it is often easy to forget that actual books exist.
I have one more question, however. On the application note you provided, (SLOA035D), it mentions at the beginning that it is possible for a single opamp to perform the amplification and the filtering. I am reading the MFB design application note, ¿Is it just setting the pass band gain to my desired 20dB in the equations provided?. Also, I assume that I do not need to impedance match to the input of the ADC but I do need to match to the signal source... ¿Am I correct?
Cheers, Luca
