Hello,
Beginner’s question
I need to test a spectrum analyzer I built
I must inject a -30dbm signal but never exceed 0dbm otherwise the input chip will burn.
I have a FY6900 generator, I would like to start from a 1V (or other if it's need) signal, otherwise the one is in the noise if too low.
My research gives me that a -30dbm signal corespond at a signal of 0.02vpp or 0.0070711 vrms
see here:
https://coretechgroup.com/dbm-calculator/I only have a telonic 0-80db variable attenuator but 75 ohm.
It can be used and what value to put to have about -30dbm?
You tell me you plug in the generator on one side and watch the box with an oscilloscope before plugging in?
In short, your best solution
cdt
