Author Topic: Small 5V supply from AA batteries  (Read 16836 times)
Offline ez24
  • L.D.A.
Re: Small 5V supply from AA batteries
« Reply #26 on: August 26, 2016, 12:13:01 am »
0.39 USD
This is the cheapest thing I have seen with free shipping.
Offline ebclr
« Reply #27 on: August 26, 2016, 01:21:39 am »
I have one, if you want i can do some tests you may want
Offline ebclr
« Reply #28 on: August 26, 2016, 01:23:59 am »
50W for sure is typo, 1A 5V = 5W
Offline sleemanj
  • Professional tightwad.
« Reply #29 on: August 26, 2016, 02:48:02 am »
50W output capacity sounds impressive. Colour me skeptical.
They are fixed 5v output and can do up to about 600mA tops, I'll leave you to do the math :-)
They do work OK and are good for low current demands from even a single AA cell (or parallel cells) as they will run down to a very low voltage.
« Last Edit: August 26, 2016, 02:49:44 am by sleemanj »
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #30 on: August 26, 2016, 03:35:04 am »
Could you just use a usb battery pack?
This.
Offline ez24
  • L.D.A.
« Reply #31 on: August 26, 2016, 03:50:20 am »
Offline Zero999
  • 0999
« Reply #32 on: August 26, 2016, 08:27:11 am »
Any voltage regulator uses extra energy. It's true that a linear regulator is less efficient than a switched mode but it still uses more energy.
Offline tszaboo
« Reply #33 on: August 26, 2016, 09:08:49 am »
This.
A lot of the battery packs are designed to charge phones. If you dont load them with, say 50mA, they shut down. Forget using the cheap and excellent Xiaomi power bank to run an Arduino for example. Others use DC-DC converters with quiescent current higher than your actual load.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #34 on: August 26, 2016, 03:33:33 pm »
This.
That's a possible issue,but as a quick & cheap solution it's worth a try. I've used them for various random stuff and I don't recall having switch-off issues above about 50ma. Ymmv of course.
Day Job: Mostly LEDs
Offline Chalcogenide
« Reply #35 on: August 26, 2016, 05:49:58 pm »
I have a few of them. When you remove the built-in LED, the quiescent current is <0.5mA which is still quite significant. It also increases fairly rapidly when the voltage gets lower than a couple of volts. BTW, the USB connector is awful quality, but for the price I don't even know how can they afford to have one.
