A USB device is required to expose a capacitance on the VBUS pin of its connector of CRPB. Thiscapacitance shall be greater than CRPB min for voltages on the VBUS pin from 0V to 5.25V,regardless of whether the USB device is powered or unpowered.
QuoteA USB device is required to expose a capacitance on the VBUS pin of its connector of CRPB. Thiscapacitance shall be greater than CRPB min for voltages on the VBUS pin from 0V to 5.25V,regardless of whether the USB device is powered or unpowered.http://compliance.usb.org/index.asp?UpdateFile=Electrical&Format=Standard#59http://www.usb.org/developers/docs/usb20_docs/usb_20_121314.zip
Quote from: Monkeh on January 29, 2015, 04:23:02 pmQuoteA USB device is required to expose a capacitance on the VBUS pin of its connector of CRPB. Thiscapacitance shall be greater than CRPB min for voltages on the VBUS pin from 0V to 5.25V,regardless of whether the USB device is powered or unpowered.http://compliance.usb.org/index.asp?UpdateFile=Electrical&Format=Standard#59http://www.usb.org/developers/docs/usb20_docs/usb_20_121314.zipSo put a 1uF capacitor on 5V line and leave it at that. Good to know!
