Author Topic: Fkc05-12D12 regulator module...  (Read 1240 times)
Offline AmmoJammo
« on: June 06, 2014, 01:06:28 am »
I was going to use one of these just to get a -12volt rail, but found out that if the rails aren't evenly loaded, they become unbalanced... 60ma load dropped it to -11.8volts.
http://www.amtex.com.au/power_pdf/FKC05%28W%29.pdf
I've already designed the pcb with this part, but can always change it...
Is there another option to easily get -12volts at upto 100ma, from a 15-19volt input voltage?
Thanks!
Offline jahonen
Re: Fkc05-12D12 regulator module...
« Reply #1 on: June 06, 2014, 03:43:49 pm »
If you need just the negative voltage, you can use single output type and connect positive output to your ground. This works because the module is isolated.
Regards,
Janne
Offline AmmoJammo
« Reply #2 on: June 06, 2014, 10:01:56 pm »
I already had this part, so I designed the board around it, before I tested what it did with an uneven load  :--
