Author Topic: Small Efficient Power Supply  (Read 8870 times)
Offline tony3dTopic starter
« on: July 11, 2021, 07:06:48 pm »
Hi, I’m slightly above a beginner, and I have limited space on my desk. I was wondering if anyone knows about this space saving little power supply? It uses GAN transistors from the looks of it. It obviously is a switch mode supply, and I can’t find any real tech review about noise, or turn on spikes. Does anyone have any real info on this little thing. It would be perfect for me, but I don’t want something that will destroy my projects. It’s made by ToolkitRc, and the model is a P200 it’s supposedly 30v 10a. Thanks!
« Last Edit: July 11, 2021, 07:12:50 pm by tony3d »
Online ledtester
Re: Small Efficient Power Supply
« Reply #1 on: July 12, 2021, 05:34:12 am »
Interesting device.
On page 15 of the user manual which you can find on https://www.toolkitrc.com/P200
has these specifications:
1235534-0
I wonder what they mean by "adjustment period" -- perhaps that's the time it takes for it to change to a new voltage setting.
The 1 ms response to over-current is kinda in the same ballpark as the Korad KA3005 according to this test:
Bench Power Supply Testing, Homemade vs. Korad KA3005 vs. LongWei LW-K3010D - TheStuffMade
https://youtu.be/RdT-xWC4h4k
Offline brucehoult
« Reply #2 on: July 12, 2021, 06:00:51 am »
As you've no doubt already found, there are a few reviews on youtube and regular web and everyone seems to like it.
Several of them have checked the output voltages with a multimeter but I haven't seen any check with an oscilloscope which is a bit unfortunate.
As the various reviewers note, you can buy a higher capacity bench power supply for less money, but much bigger and clunkier, and without many of the nice UI features including usage graphs etc.
I've never had an adjustable power supply with current limiting, so I'm tempted. It's cute.
Dave needs to torture test one for us.
The following users thanked this post: Capernicus
Offline ataradov
    • Personal site
« Reply #3 on: July 12, 2021, 07:20:03 am »
I tried to find any reviews that would actually check the performance, but it looks like they seeded review units to RC people, and they don't have proper equipment to test. And to be fair, they don't really care for fast response times for their typical use cases.
It is pretty compact, it would be nice to see it put through a real test.
Alex
Offline viperidae
« Reply #4 on: July 12, 2021, 11:55:27 pm »
It looks like it is only rated for 100W output when plugged into the mains. For 200W output, you need to supply it with DC.
That would explain some of its compact size, the AC switch mode side is only rated for 100W.
Offline brucehoult
« Reply #5 on: July 13, 2021, 01:10:41 am »
"looks like"? It literally says that in big letters on the front panel. :-) :-)
But would such a small and light device not be using a switch mode DC to DC converter *all* the time?
Offline skander36
« Reply #6 on: September 05, 2021, 01:46:02 pm »
It can output max 178 W on AC.
For DC I didn' test it. ON USB type C it is recognized as SuperFast Chager with PD PPS protocol displayed.
- Min. - 1 V / 0,5A
- Min setting step is 50 mA/mV (adjustable until 500 - 50/100/150/200...500)
It makes audible noise under load and it has an instability when output is on, that makes internal temp to rise to 45C. This trigger the internal fan that makes internal trafo or inductors (or ther components?) to make an annoying beep until the fan stops.
There is someone that can confirm this ?
Quite noisy but understandable as this primary scope is charging LiIon accu's for RC models.
« Last Edit: September 06, 2021, 04:22:30 pm by skander36 »
Offline iMo
  • Country: pw
« Reply #7 on: September 05, 2021, 02:05:54 pm »
People made the "red led" test with their PSUs  :)
Set voltage to 30V and current limit to 20mA, then connect a red led - whether it survives..
Offline skander36
« Reply #8 on: November 13, 2021, 07:44:55 am »
Not so long life ...
After only a short of output wires (they just touched one or two times for a fraction of seconds) the source has cracked. Pics attached.
I understand that this can be a defect on only my source , but ... be aware. No output protection on short circuit ...
Bangood initially said that will send me a power board, but after that they changed and say that will refund me.
The buck convertor part is still alive and can be used with DC (12V).
Can anyone take a picture of their power board and tell me what component (U2) is that wtih a hole in it?
Thank you very much!
« Last Edit: November 13, 2021, 08:21:04 am by skander36 »
Offline brucehoult
« Reply #9 on: November 13, 2021, 09:08:29 am »
The diagonal part of that vertical trace in the center of the board doesn't look healthy.
Offline skander36
« Reply #10 on: November 13, 2021, 10:32:32 am »
Yes, it is "exploded" .
This board look clean just because I cleaned it. It was all black from smoke. The internal space is very limited.
Some diodes I also found dead ... but I thnk it can revive ... I hope :)
« Last Edit: November 13, 2021, 10:44:39 am by skander36 »
Offline CaptDon
  • Country: is
« Reply #11 on: November 13, 2021, 01:19:16 pm »
Cheap Chinese junk designed for charging the batteries of radio controlled model cars etc.  A simple short blew it up, evidence of a crappy design. Most definitely NOT suited for the hobbyist / experimenter workbench!!! If you intend to use the supply with radio equipment you probably want a linear supply which will be heavy and run warm with little or no R.F.I.  If you intend to do non-radio related projects then a 'switcher' style supply would be lighter with higher current capability. You should have a really large 'stabilizing' capacitor available if you have projects that demand peak spike current which could be 5 to 10 times the rated current of the supply. Switcher power supplies go into current limit and fall on their face when subjected to spike currents, linears with their large output ripple filtering capacitors can handle spikes very well!! I have a 120,000uf @ 75vdc capacitor as my 'spike energy source' with a 10 amp fuse in series with it. That capacitor when charged to 75vdc (locomotives are 64vdc / 72vdc nominal) will burn holes in sheet metal and blow traces right off of circuit boards when things are amiss!!!
Offline skander36
« Reply #12 on: November 15, 2021, 08:49:00 pm »
Keep cool. It was aquired just for play, for how it look. I'm not with the RC's ...
I have a plenity of other sources on my bench, but people on this forum love to revive electronics.
I'm just asking here, maybe one of the people who have this power source find time to make a photo of the power board.
Thanks in advance!
Offline brucehoult
« Reply #13 on: November 15, 2021, 10:01:55 pm »
Uh ... the whole point of having a "maximum current" setting on the front panel of these things is you DON'T WANT the power supply to exceed that current setting if the load "demands" more by, for example, having a short circuit.
Having a huge capacitor on the output defeats the entire purpose.
As someone said: set the voltage to 30V and current limit to 20mA, then connect a red LED and see whether the LED survives.
The aim of a good experimenter's bench power supply is that the LED *does* survive this, because the power supply drops the voltage to limit the current quickly enough that significant energy doesn't go into the LED. Your huge output capacitor is the opposite of this -- you'll be picking bits of the LED out of the ceiling (I exaggerate).
I have no idea whether good bench power supplies (or this one) actually pass this test. It would sure be nice if they did.
The power supply itself blowing up if the output is shorted seems very bad.
Offline CaptDon
  • Country: is
« Reply #14 on: November 15, 2021, 10:35:47 pm »
Don't have to have that surge capacitor online if not needed, sadly our locomotive stuff has run currents around 1 to 5 amps and inrush at 70+ amps sometimes. So on SMPS supplies they sit there and go twitch, twitch, twitch, twitch, run. Unless I have the stabilizing cap online. I put stackable banana plugs on my cap. The old Sorensons (we have 1, 2 and 3kw versions) all have current limiting AND huge output capacitors. Sometimes you need REAL safety current limiting, and sometimes you need to simulate two 32 volt railroad batteries in series, each 3ft long, 2.5 feet wide and 1.5 feet tall capable of not dropping below 50 volts when drawing 1500 amps on a cool morning, but you don't have room in the lab for the batteries, or the safety assholes won't let you have them in the lab "Because they say so!!!". I'm not sure if a .1uf cap charged to 75vdc would kill an LED or not, I have seen a lot of 'high quality' SMPS units with a .1uf across their outputs, guessing for noise reduction. But then again, not to many of the dudes on this board have supplies upwards of 30-50 volts anyway. 72vdc on a running locomotive gives you a nasty bite or sting when the weather is dry and your hands are dry, but it will rock your world in your hands are damp/wet or you have a nasty unprotected cut on your hands, which seems to happen a lot when working on locomotives!!
Offline skander36
« Reply #15 on: November 16, 2021, 10:48:49 am »
As I said in a post above : this source allow a minimum current of 0,5A - 500mA, so stop with that LED test ... :)
Offline Larsinka
« Reply #16 on: February 21, 2022, 02:13:41 am »
Hey man, here's a picture of mine. Hope it helps. Seems to be the main GAN fet which isn't really cheap but still cheaper than buying a new PSU ;)
Navitas NV6117
The following users thanked this post: dagobird
Offline skander36
« Reply #17 on: February 21, 2022, 10:51:30 pm »
Hi Larsinka!
Thank you very much for your effort.
This chips is quite cheap. I found it on Digikey on around 3 Euro.
https://www.digikey.ro/ro/products/filter/pmic-comutatoare-de-distribu%C8%9Bie-a-energiei-drivere-sarcin%C4%83/726?s=N4IgTCBcDaIHIEMBuBLALggzgAjgNQDYBGIgdhAF0BfIA
When I contacted Toolkit, they offered to send me powerboard for 52 $ but shipping from China to Romania and  customs cost me almost  as a new one, so yes is cheaper to repair.
Offline 350D
  • Country: ee
« Reply #18 on: April 25, 2022, 03:07:31 pm »
My P200 exploded after few seconds working on 16V/2A powering my flight controller with faulty esc. Same chip destroyed.
Seller send me replacement part for 14$
I've expected a bit more from bench power supply for this money.
Online Fraser
« Reply #19 on: August 29, 2022, 03:51:30 pm »
I needed a compact variable power supply for charging batteries and quick power tests on equipment. This little unit appears one of few choices in the market that are truly compact. At the price it seemed more expensive than its larger cousins but you expect to pay a little extra for the size reduction. It is interesting to see that some owners have suffered failures when the u it is shorted or over-loaded ! Not a great start but may be bad luck / early firmware ? I note that the firmware has had some revisions to address some issues including the current limit timing and minimum constant current boundary.
I ordered a P200 unit as it’s small size is important in my case and I have plenty of larger Lab Power Supply units for more serious work. I looked at the Miniware power supply but it’s design did not appeal and it appears overly expensive.
To those who suffered failures of the P200, did you manage to repair it ? Mine is coming from a respected UK shop so I do have a warranty if it fails in the first year.
Fraser
« Last Edit: August 29, 2022, 03:53:58 pm by Fraser »
Offline radiolistener
  • Country: Earth
« Reply #20 on: August 29, 2022, 04:11:49 pm »
I don't recommend to buy compact power supply, especially Chinese, especially switching mode... :)
It can burn your load, can make fire, can shock you or even kill... This is dangerous, not reliable and very noisy (both - sound and RFI).
The good power supply is linear one. Large size and heavy weight == more good quality, because heavy transformer can run at higher power and large dimensions with large radiators leads to better cooling to avoid overheating  :)
I recommend you KORAD KA3005P, if you want better noise floor, try to find linear power supply with no digital electronics (with analog Voltage indicator and mechanical potentiometers).
« Last Edit: August 29, 2022, 04:21:12 pm by radiolistener »
The following users thanked this post: Fraser
Offline strawberry
  • Country: lv
« Reply #21 on: August 30, 2022, 06:54:12 am »
R220 seems too small 1V / 0,22 = 4,5A / ~2 = 2,3A * 150Vdc = 345W
No wonder they removed heatsinks after revision 1,2  :-DD
Online Fraser
« Reply #22 on: August 30, 2022, 09:46:33 am »
Strawberry,
Interesting comment. Have you reverse engineered that part of the power supply ?
I will be using my P200 in very non demanding roles. I just need a neat compact variable power supply to quickly test kit or put some charge into discharged batteries to wake them up from their sleep. I have decent quality linear and switch mode programmable power supplies in my lab but they are not very compact for having on my Home Office desk in our spare room. I often just need a particular voltage with reasonable current capability, normally less than 3A. I think the P200 should cope fine in that role.
In one of the reviews I noted a comment that the noise levels on the output of this power supply are higher than would normally be expected for a lab power supply. But this is not really a lab power supply, more a general purpose variable supply for less demanding roles. I might look at improving the power rail noise levels with additional filtering though.
Interested to hear more about that resistor and it’s value that you have mentioned. What is the story on the heatsinks please ?
Fraser
« Last Edit: August 30, 2022, 09:49:44 am by Fraser »
Online Fraser
« Reply #23 on: August 30, 2022, 10:29:36 am »
Teardown video of the P200….
https://youtu.be/ju0rDFaFBMM
I am wondering which Switching controller they use on the AC to DC mains input supply. Maybe some modifications will make that input power supply a little bit more robust !
Fraser
Offline strawberry
  • Country: lv
« Reply #24 on: August 30, 2022, 03:59:52 pm »
maybe flyback(resonant)
Navitas NV6117  maybe short circuit protection too slow for 1,8ºC/W   0,25Ω conduction losses ~1,3W + current shunt ~1,3W
seen many blown ~20W SMPS with same ~0,22Ω
