I want to measure current in mA through my headphone amplifier. I put a 0.1 Ohm resistor in the low side of the circuit.
The scope GND connected to the "floating" power supply NEG output. (on the side of the 0R1 connected to the PSU -). I understand this will earth the PSU it's fine.
The scope probe was clipped to the other side of the resistor.
On the scope however, all I can see is 2 traces. Not 1, 2. The smaller low frequency signal (the current/voltage drop I want) is modulated on top of a larger wide noise band in the high kHz and MHz. It's there even with the 20Mhz bandwidth limit on.
Neverminding the particular measurements in this case, it's a recurring problem I have with the scope. Seeing a "wall" of noise with your signal modulated on the "top trace" and the "bottom trace".
Are there any trips tricks to collapse these?
In the particulars of this test: The circuit under test is a headphone amp. The signal it is receiving is coming out the back of a supposed "output filterless DAC", which considering it's output has up to 400mV peak to peak digital high MHz I2S and clock noise might .... you know... need a filter on it. This is almost certainly the main source of noise. Secondary source would be the radiated noise from the same digital circuit. I may need a bigger resistor or a few 0.1R in series to get to see a 40mA trace.
So, other than a low pass filter on the DAC output, is there any scope magic I can try?
