does it work?
Yes, both the circuit and buzzer work.
The diagram was from the author of the circuit.
I am learning to use Geda to create my own circuit diagrams.
I looked for a symbol for a piezo buzzer. The closest I found looked like a speaker with plus and minus terminals.
It was quite a leaning experience going from the solderless breadboard to soldering the components in the final board.
Learned a lot and it will take quite a bit of practice to get good.
I will eventually need a temp controlled iron as my "Hakko knockoff" was overheating as the dial readings did not correspond to the actual tip temperature.
Andy
Andy
