No, I didn't read the data sheets on the three candidates. I think you said you had to wait for two of them as they are not in production. All three would require a board spin. What would you like me to look at exactly?
yes that would require board respin as an updated version, let's call it version 2. which is not top priority right now. I wanted your opinion about using these as the main part in v2 of the board which is gonna be without linear stage. will they be good enough to reach <10mV ripple\noise? perhaps even lower than that?
TPS62913 is the only one which is still in pre-production, the others are active. LM61460 seems good but only 1 output at relatively high price, while LT8652S has 2 outputs in one package with price of 6.5$ @ 100 quantity, very pricey but gonna be enough to do everything by itself plus passives. do you know better switchers in terms of output ripple?
If 100 uF is the minimum that makes the circuit stable then you definitely want to use the 220 uF part. But you need to test with the parts you will use and get a data sheet to see what the ESR is. The ESR is likely more important than the value of capacitance.
There are many form factors for capacitors. I'm sure you can get both parts in the same height. What is important to a capacitor is volume. More capacitance or more voltage means more volume if all else is the same. There is no reason to let the form factor dictate the electrical value of the capacitor. What height are you using? Our project is using some large value caps that are pretty compact, 8.3 mmsq x 10 mm tall, 1,000 uF, 25V. Since you can use a smaller value and voltage you should be able to find a much smaller package. Have you used Digikey's search facility?
the ones I will get are 220uF 16v elec. caps which are leaded not smt, and from local suppliers. will never get them from outside. I have small quantity here and they are tiny, like 7mm in length which is suitable to the board since I am gonna hand solder them and situate them where it fits.
However, for the enhanced version of this current design (call it v1.1), I will include smt elec. caps on board for sure while removing 1nf opamp to mosfet gate caps. footprint won't be a problem since we need 6.3v rated caps which are generally small. I guess we can even get 470uf with low footprint, gonna get down to do it sometime in near future.
Also, I have included a pi filter (1uH inductor with ceramic caps before and after it) for both switchers output just before linear stage. its placement in layout is not perfect but probably better than before.
What is the frequency of the switchers you have designed in?
we went for 2 MHz.
Did you look into the many USB attached digital oscopes available and reviewed on this site? I think many of them will do the job you need with a price around $100.
I know some Hantek and Owon ones. getting them to me in Jordan will have shipping costs and customs.
I saw
this one on Amazon for quite good price. gonna take 41$ shipping and customs fee. However it doesn't support AC coupling!
this one seems better but it will cost 150$ to get here.
I will wait to see what happens with that DOS1102 used scope for now.
