I have a small (5HP) outboard motor with a battery charging coil. I'd like to get more electrical power out of it, especially at lower RPM, to charge a lead acid battery faster. Please bear with me and my stupid questions as I'm a mere ME.
This is the coil and rectifier kit:
https://www.tohatsuoutboardparts.com/Electrical-Kits.htmlThe first thing to note is that the rectifier kit is just a single rectifier -- not a full bridge rectifier. Secondly, there is no voltage regulator or any other electronics except for the rectifier. There is a 10 amp in-line fuse.
I have easy access to both wires from the coil, so I was thinking of changing to a full bridge rectifier. This should roughly double the power output (for a given voltage), right?
The obvious danger I see is the possibility of overheating the coil. Are there other problems I'm missing?
Thanks for your thoughts.
If anyone wants the details, here's what I know:
Coil wire diameter - 1 mm
Number of turns - probably 200, that's 50 per layer with probably 4 layers (but possibly 3 or 5 layers)
There are 4, rather long, magnets glued inside the flywheel, I don't know the arrangement of the poles.
The maximum RPM of the flywheel i s around 5000.
