Author Topic: voltage on oscilloscope  (Read 33512 times)
Offline Bored@Work
Re: voltage on oscilloscope
« Reply #25 on: June 06, 2011, 05:57:27 am »
First of all, I have already order the probe before I asked the question.
You ask for buying advice after you already bought? Thanks for confirming you are an asshole and your only intention was to waste our time.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #26 on: June 06, 2011, 06:49:19 am »
can we cool it please, I think all points have been made well enough by now.
If we are talking rigol scopes (DS1xxxE/D series) the maximum that you can measure is 30V, 300V with a 10X probe and therefore 3000V with a 100X probe.
The 300V figure on the front panel is part of the CAT rating and means that if you give it a spike of more than 300V it will probably deservedly die as it is 10X the measuring capacity.
Offline xian
« Reply #27 on: June 06, 2011, 08:51:52 am »
You, sir, are and idiot.
