Author Topic: SMD flat silent buttons  (Read 805 times)
Offline YarooooTopic starter
« on: February 09, 2020, 11:41:08 am »
Hi all,
I'd like to find a small silent tactile switch to substitute my loud "Click" switches. These are common momentary SMD switch found on every board.
Here's an example image:
924532-0
Dimensions are 6x6.5x2 mm.
Looking on internet I can't find silent switches of this dimensions, especially height.
I found a lot Keyboard switches and the smaller one is this, used inside silent mouse (6x6x6.5)
924536-1
Did I use wrong terms when searching or is it impossible to have 2mm height button with silent attribute due construction?
« Last Edit: February 09, 2020, 11:42:45 am by Yaroooo »
Offline jbeng
Re: SMD flat silent buttons
« Reply #1 on: February 11, 2020, 01:42:36 am »
Here's a link for a datasheet from C&K which might give you some ideas.  I'm not sure if they have something in the height you require, but the KSC2 series are quiet.  Not 100% silent, but the actuator button is rubber, so they are quiet.
https://dznh3ojzb2azq.cloudfront.net/products/Tactile/KSC2/documents/datasheet.pdf
"It's such a fine line between stupid and clever" - David St. Hubbins
Offline tooki
« Reply #2 on: February 11, 2020, 02:44:04 am »
I think that for something like that, “silent” and “tactile” are very hard to unite, since the tactility comes from a collapsing metal dome, which will cause some click to resonate through the PCB. Some will be much quieter, but not silent like a linear keyboard switch.
What about those metal domes that you solder right to the PCB?
Or an actual rubber membrane keypad?
