Author Topic: SMD Micro USB Type B port solder-pad footprint to header  (Read 1053 times)
Offline ahfdjpiTopic starter
« on: August 22, 2018, 10:33:47 pm »
Goal:  I want to hard-wire a USB 2.0 cable to an SMD USB 2.0 type B port solder pad in a way that is mechanically robust (similar in mechanical characteristics to a AWG 28 conductor soldered through-hole).  I want to do this by using a adapter component that uses the same SMD footprint as a micro USB 2.0 type B port, but that provides header pins (or larger, more robust solder pads or a through-hole platform) to connect to INSTEAD OF a standard type B micro USB port (kind of like a soldered-on breakout board, but just for the micro USB type B port).  This adapter would provide more mechanical strength between the SMD solder pads and the cable conductors.
Does such an adapter component exist?  Are there other, better workarounds?
« Last Edit: August 22, 2018, 10:36:11 pm by ahfdjpi »
Offline westfw
Re: SMD Micro USB Type B port solder-pad footprint to header
« Reply #1 on: August 22, 2018, 10:59:53 pm »
There are micro USB-B connectors available with long-ish through-hole tabs that should be much more physically robust that the more common all-SMT-pad versions.
