Author Topic: SMD Soldering practice kit instructions  (Read 8254 times)
Offline hamster_nzTopic starter
« on: November 30, 2017, 12:47:57 am »
In the 11/11 sales I purchased a few of the $0.99 (with free shipping) SMD soldering practice kits that arrived yesterday.
https://www.aliexpress.com/item/2016-New-Both-Sides-SMT-SMD-Electronic-Component-Welding-Practice-Board-PCB-Soldering-DIY-Kit-Skill/32595680463.html
They are nothing too exciting - a NE555 connected to a CD4017, a few transistors and diodes, and plenty of LEDs and resistors and a couple of caps - around 50 parts in all on the active side.  On the back side they have "bonus challenges" - 0603, 0402, and some resistor packs.
However... the instructions are in Chinese. That's not a problem for me, as I've worked from the schematic without any issues.
If anybody is keen to give it a try, but being held back by the lack of English instructions then let me know and I'll spend some time making some English ones.
Offline kalel
Re: SMD Soldering practice kit instructions
« Reply #1 on: November 30, 2017, 01:01:39 am »
If you tried one, what did you use to do the soldering?
« Reply #2 on: November 30, 2017, 01:21:11 am »
Just a bog standard 45W temperature controlled iron, with a 2mm conical tip, & 0.71 mm solder wire.  Would not do the 0402 with this though, I would put in a 0.5mm tip and consider using paste.
I did have to get my second iron out to to swap around an LED I put on backwards...  :D
Offline kalel
« Reply #3 on: November 30, 2017, 01:27:17 am »
Good work, I would probably need more practice, then, there's only one way to learn... Those kits are relatively cheap (and so are custom PCBs these days).
Offline rthorntn
« Reply #4 on: April 03, 2018, 05:13:15 am »
I just got some of these, hamster_nz could you do some instructions please?
« Reply #5 on: April 03, 2018, 08:28:48 am »
Here is the very rough English instructions:
Theory of operation
The NE555 timer is set up to run as an astable oscilator, with a frequency determined by R48, R49 and C27.
f = 1.44/((R48+2*R49)*C27)
f = 1.44/((1000+2*2000000)*0.0000001)
f = approx 4 Hz
The output of the NE555 drives LED D1, with R50 controlling the current through the LED.
It also drives the clock input of the CD4017 decade counter. Only ne of the outputs of the counter (Y0-Y9) is on at any time, and then each time the clock signal rises it moves on to the next output - taking 10 cycles to return to the original state. Each of the 10 outputs drive an LED, through a current limiting resistor.
The CD4017 also has a "carry output" Is the input divided by 10, and goes from low to high when the selected output wraps from Y9 back to Y0. This output is used to drive four transistors, which in turn drive the four LEDs in the corners of the board. The four diodes are not functionally significant, but R61-R64 limit the current into the transistor, and R65-R68 limits the current through the diodes.
Parts list
Qty Value Pkg Part
1 Circuit board 48x60mm PCB
1 NE555 SO-8 U1
1 CD4017 SO-16 U2
2 0.1uF Capacitor 0805 C27, C28
11 Red LED 0805 D1-D11
4 Blue LED 0805 D11-D15
4 1N4148 L34 D13-D15
4 S8050 SOT-23 Q1-Q4
1 2M Resistor 0805 R49
15 470Ohm Resistor 0805 R50-R68
Additional parts (for the back of board, not actively used):
Qty Part  Pkg
8 1206 Resistor 1206
20 0603 Resistor 0603
20 0402 Resistor 0402
6 Resistor array 0603*4
Assembly
Step 1
- Identify R49 (2M Ohm Resistor - marked 205) and solder in place
- Identify R48 (10k Ohm Resistor - marked 103) and solder in place
- Identify C27 & C28 (0.1uF Capacitors - unmarked) and solder in place.
- Solder the NE555, taking care to orient it correctly.
- Identify R50 (470 Ohm, marked 471) and solder in place
- Identify the LED D1, and solder in place. Take care to orient the green stripe to the striped end
- Attach some power wires to the + and - pads, to allow it to be attach to your power source
Test - the LED should blink a frequency of about four times per second. The most common problem the LED is the wrong way round,
Step 2
- Solder on U2, taking care to orient it correctly
- Solder on LED D2, taking careful note of orientation
- Solder on the R51 (marked 471) resistor for the LED
- Test - it should come on briefly once every 2.5 seconds
Step 3
- Solder on the rest of the LEDs and resistors in the circle.
- Test - all the the LEDs should light in sequence
Step 4
- Solder on the four diodes D12 - D15
- Solder on the four transistors, Q1-Q4
- Solder on the four remaining 470 ohm resistors, R65-R68
- Solder on the four remaining LEDs, D16-D19
- Test
Project Complete!
The following users thanked this post: rthorntn, HecticZA, llopis
Offline rthorntn
« Reply #6 on: April 04, 2018, 04:00:23 am »
Fantastic, thanks hamster_nz!
Does anyone want to have a crack at helping a beginner out?
So I get that you need resistors to stop the LEDs taking too much current (r50-r60?)
I also get that you setup the timing of the 555 with resistors (r48 r49?)
The 555 output is 4Hz which feeds the CD4017, so 4 a second, so that lights each LED in sequence, the sequence should complete in 2.5 seconds?
What is D12-D19, R61-R68, D16-D19 & Q1-Q4 (why NPN transistors, what are they doing, amplifying, switching?) for, its connected to "carry out" (it completes one full cycle for every 10 clock cycles, hamster_nz has it's the input divided by 10, I'm confused about this?), what exactly is happening here, why 8 resistors, what does the "four diodes are not functionally significant" mean, what do the four LEDs do here - flash every 2.5 seconds?
Thanks all!
Richard
« Reply #7 on: April 04, 2018, 04:09:16 am »
Correct
The pin on the decade counter is not designed to drive enough current to light all four LEDs, so Q1-Q4 act as switches. Four resistors limit the current flowing into the base of the transistors, and the other four limit the current through the LEDs when they are lit.
The four standard (non-light-emitting) diodes don't  have any real purpose. the circuit will run just fine if they are replaced with wire links or solder bridges. I guess they are there so you can experience the fun of soldering the diodes in small round glass packages.
Offline rthorntn
« Reply #8 on: April 04, 2018, 04:34:53 am »
Perfect, thanks, last question D16-D19 what frequency do they flash at?
Offline rthorntn
« Reply #9 on: April 04, 2018, 06:30:14 am »
Also is D12-D15 purpose to block the flow of current in the reverse direction? Thanks!
« Reply #10 on: April 04, 2018, 11:52:01 am »
They flash at the same frequency as the circle of LEDS - 1/2.5 Hz. The interesting thing is the duty cycle. Take another look at that CD4017 waveforms from the data sheet you included a few posts back. It should make it all clear.
If assembled correctly, there is no chance of the emitter on the transistor getting much higher than 0.7V, and even then that will only occur when the diode is forward biased. I really can't imagine any reason for them being there, apart from soldering practice.
Offline rthorntn
« Reply #11 on: May 07, 2018, 07:40:02 am »
Edit: I can get continuity on on side of R48 but not on the other side.
Hi All,
Please be gentle, my first attempt at SMD soldering, haha, it doesn't work at the end of step 1.
Using a Hakko at 320C with 60/40, I'm not adding extra flux.
If someone can spare the time please take a look, looking for theories, tips or what I could do to troubleshoot with a DMM?
I potentially destroyed something with heat, the components just move around when I get near them with the iron.
I accidentally attached U2 (not sure if it matters)
I got 20 of these kits so I will keep practicing :)
Thanks for looking.
Richard
« Last Edit: May 07, 2018, 08:32:32 am by rthorntn »
« Reply #12 on: May 07, 2018, 08:37:33 am »
Hi Richard
R50 doesn't look to be attached at both ends.
Do you have any 'realy good' tweezers? I find mine invaluable. The are so hard and sharp that they are dangerous :)
Here is my process....
0. Iron about 280.
1. Tin one pad. The quantity of solder on the diode pads loots fine. (If I tin both I can never get the part to sit flush).
2. Place and hold part with tweezers.
3. Solder the tinned pad by just heating it
4. Check, reheat and adjust if needed.
5. Then solder the second pad, using more solder wire.
6. Reheat the first pad till it melts. If the part moves then the solder at the other end hasn't wetted correctly.
7. Solder any other pads (eg transistors, ICs)
I still need wick and/or a flux pen on the ICs more often than not..
As they now say in school... Practice makes perfect!
« Reply #13 on: May 07, 2018, 09:13:22 am »
Thanks for looking.
Richard
It is only fair that you can chuckle at my soldering too (it is the blind leading the blind). The local shop only has 0.7mm solder, and I always end up with too much on the joint!
Offline rthorntn
« Reply #14 on: May 07, 2018, 09:21:25 am »
Thanks hamster_nz! Could you please post a picture of an entire soldered board so I can use it for reference?
I can get continuity on one side of R48 but not on the other side, should I be able to get continuity through a 10K ohm resistor?
« Reply #15 on: May 07, 2018, 09:33:36 am »
Top row (with black on the '-' pad.
R48 5V
R50 jumps around
R49 Jumps between 1.3V and 3.8V
C28 Jumps around.
C27 0V
Other ends
R48 Jumps betweem 1.3V and 3.8V
R50 Jumps around
R49 mostly around 2V
C38 around 3v3
C27 Around 2.5V (jumping)
555 pins
1 0V0
2 Jumps around (same as pin 6)
3 Jumps
4 5V0
5 3V3
6 Jumps around (same as pin 2)
7 Jumps around
u 5V0
« Reply #16 on: May 07, 2018, 10:07:58 am »
See attached.
A 10k is too high to pass a continuity test.
Offline rthorntn
« Reply #17 on: May 08, 2018, 06:23:06 am »
Thanks, Pin 8 on the 555 wasn't connected well enough, I added a dab of solder and it works!
