This is part of a homework/lab circuit. I'm trying to match the output of a single transistor 1GHz amp (common emitter) to a 50 ohm line, using a double-stub tuner (microstrips). The output, the collector, has a TL of length (L2) 10mm to 20mm connected to the 1st stub, then 1/8 wavelength between the stubs. Some length after the 2nd stub there is a chip capacitor (DC block; 0.1uF), then 10mm to the SMA connector.
Zout = 143.1 @ -35.1deg
--> y_out = 0.286 + j0.201 (normalized admittance wrt. 1/50 S)
wavelength = 166.99 mm
This question is really about Smith chart usage, but I know you techies love details.
I've rotated y_out towards the load (ccw) to wavelengths corresponding to L2, and I've rotated the y=1+jb circle towards the generator (cw; it is now at the top of the chart). Now I need to follow the susceptance lines from the translated y_out point to intersect the translated y=1+jb circle to determine the susceptance change required and hence the length of the stub.
Which way do I go: clockwise or counter-clockwise? Normally, when matching a load, you'd go clockwise - is it reversed in this case, matching an output stage to a line? My book [Pozar] implies that I can go either way, which doesn't really make sense to me, as the length of the arc corresponds directly and linearly to the length of the stub. That brings me to my second question:
how do I determine the length of the stub, in this case?can of Smith chart solutions with L2 = 10mm, 15mm, and 20mm:
[75dpi; 1 MB] or
[300dpi; 15 MB] Question pertains to the blue arrows, between the A's and B's, and the green arrow (on the g=1+jb circle), between the C's and g=1.
