Author Topic: EMI filters for hsync and vsync.  (Read 866 times)
Offline fabiodlTopic starter
« on: February 24, 2022, 10:00:36 am »
I noticed that the dreamcast vga box (pics here https://shmups.system11.org/viewtopic.php?p=867369#p867369)
use emi filters in series with the hsync and vsync lines of the VGA.
I am replicating the circuit. What EMI filter would you use?
Offline Terry Bites
Re: EMI filters for hsync and vsync.
« Reply #1 on: February 24, 2022, 11:46:12 am »
Hi
Your link is to a whole blog- no chance of finding the specific schematic.
Are you referring to the pull-up reistors and diodes on the sync lines?
They are simply there to clamp the DC levels of the sync pulses.
« Reply #2 on: February 24, 2022, 01:12:18 pm »
The link is to the post which contains pictures of the board.
The H and V lines are, indeed, protected by a diode.
One EMI filter is in series, just before the vga connector, of each of the h and v lines.
Offline Terry Bites
« Reply #3 on: February 24, 2022, 04:41:39 pm »
I tried you link again. Takes me to a page full of stuff that I'm not going to bother sieving.
Offline dmills
« Reply #4 on: February 25, 2022, 07:23:52 pm »
I also got a page of rather confused discussion of prehistoric game console video outputs...
The sync outputs are likely driven by some sort of digital logic output which will have a rather fast edge rate in comparison to the output of whatever video DAC the thing uses, I think I would probably throw some filtering on there if I was designing it.
Probably just some sort of small ferrite bead and a 100pF cap, should be fine.
« Reply #5 on: February 26, 2022, 07:26:50 am »
There's no DAC in the device itself, it goes straight into the monitor.
