using the formula from the SMPS IC datasheet R1=R2((Vout/Fb)-1),
Since you did not provide Fb value, I try to find it.
R1=R2((Vout/Fb)-1), so
R1=R2(Vout/Fb)-R2, so
R1+R2=R2(Vout/Fb), so
(R1+R2)/R2=Vout/Fb or R2/(R1+R2)=Fb/Vout
where R2 is chosen to be 56K. After solving, R1 becomes 160K.
From equation I got, it looks that not R2 but R1 was chosen to be 56k.
So, in contrast to what you wrote I assume R1=56k, R2=160k and I can find Fb to be 0.81*160/216 = 0.6V.
Now we need to find R2 for 0.89V.
From your first equation R2=R1/((Vout/Fb)-1) so R2=56/(0.89/0.6 -1)=56/0.483333=116k.
One of first things I have learned about electronic was how to calculate resistance of connected in parallel resistors R=R1*R2/(R1+R2). Later, when I learned how to transform equations I found that when we know the paralel result and one of resistors than the lacking one we can get from R2=R*R1/(R1-R). So to get 116 from 160 || with something we need 116*160/(160-116)=422k.
You have to be very young as these calculations are at primary school level. If you seriously plan to play with electronic assume math is the most important subject at school.
