Author Topic: SMPS chip but not for 240V?  (Read 4086 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: September 04, 2019, 03:49:13 am »
I have tried to learn about buck converters, with the goal to learn how you convert from 240V to 5V but I keep running into chips for low voltage except a few for 600V-1000V. Even Davids "jelly bean"  MC34063 is for max 40 voltage. Where do the 240V go in, is 40V fine, I seem not to understand how it all can be.
Hope thay uoy please will help? :-)
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline james_s
Re: SMPS chip but not for 240V?
« Reply #1 on: September 04, 2019, 03:57:08 am »
While high voltage buck converters do exist, that topology is not particularly common for such applications. There are lots of power conversion ICs out there intended for converting mains voltage down to low DC voltages.
« Reply #2 on: September 04, 2019, 05:39:20 am »
Thanks, but is that the way a standard SMPS do it?
Online oPossum
« Reply #3 on: September 04, 2019, 05:42:44 am »
Typically flyback or forward converter.
« Reply #4 on: September 04, 2019, 06:30:39 am »
I have hard of these terms but do not understand how it all works, how does Dave's jelly bean at max 40V handle 240V?
Offline brabus
« Reply #5 on: September 04, 2019, 06:39:01 am »
You usually have an external MOSFET or a BJT doing the hard lifting and dealing with the high voltages and currents. The controller only provides the driving commands for them.
Online oPossum
« Reply #6 on: September 04, 2019, 06:42:08 am »
There are offline flyback controllers with integrated switch for low power applications.
A random example... https://www.onsemi.com/pub/Collateral/FSL137H-D.pdf
Using a MC34063 with an external switch may be possible, but there are may other better choices.
Offline magic
« Reply #7 on: September 04, 2019, 06:42:19 am »
In addition, they usually use an auxiliary transformer winding which produces 5~20V for the SMPS chip.
Startup is provided by a pullup resistor which slowly charges the controller's power supply capacitors when the PSU is connected to mains. This is possible because the controller draws little power before it becomes active.
« Reply #8 on: September 04, 2019, 06:46:43 am »
Am I guessing right in that the Mosfet is better because of less voltage drop?
I'll take a good look at that! :-)
Do you mean a transformer before the SMPS circuit?
Offline MosherIV
« Reply #9 on: September 04, 2019, 06:47:11 am »
Hi.
Typically mains voltage smps rectify the mains AC into a high voltage cap.
This HV DC is pulsed into an isolation transformer at high freq.
The freq controls the output voltage/current.
The output V needs low ESR caps to smooth the output of the isolation transformer.
The output voltage is monitored and fed back via an opto isolator.
This feedback is used to determine the freq to pulse the isolation transformer.
This is all controlled by a ASIC which is powered striaght from the HV DC.
I think (but I am not sure) this is the 'forward converter' topology.
Online oPossum
« Reply #10 on: September 04, 2019, 06:51:36 am »
If it has one switch it is probably flyback. If it has two switches (or a multiple of 2) it is probably forward.
Switch refers to whatever is doing the switching - BJT, MOSFET, IGBT
« Reply #11 on: September 04, 2019, 06:53:00 am »
Hi.
Yes thats sounds logical, and like the attached drawing. But In my book it looks like that 240V is connected to the chip?
Online oPossum
« Reply #12 on: September 04, 2019, 06:53:26 am »
See figure 1 in the FSL137 data sheet.
Online oPossum
« Reply #13 on: September 04, 2019, 06:56:17 am »
That is for a bootstrap circuit that gets the chip running. Operational power comes from the transformer winding.
« Reply #14 on: September 04, 2019, 07:04:49 am »
So the 240V does not go undisturbed down to the HV-pin at the chip?
« Last Edit: September 04, 2019, 07:17:46 am by FriedMule »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #15 on: September 04, 2019, 08:37:57 am »
That is rare - the most common arrangement is a resistive dropper from HV to get it started, then use a winding on the transformer for normal running.
There are some pure buck converters designed for mains voltages, look at Power Integrations' LinkSwitch series.
The reason that simple buck converters aren't common for mains is that mains PSUs usually need isolation, so a flyback with a transformer makes the most sense.
Day Job: Mostly LEDs
Offline tunk
  • Country: no
« Reply #16 on: September 04, 2019, 10:13:41 am »
I guess it's a bit beside the point, but the 240V is an average and
after rectification and smoothing it's more like 340V (240*2^0.5).
You could also take a look at some of DiodeGoneWild's youtube videos.
« Reply #17 on: September 04, 2019, 10:26:17 am »
Oh, that makes a  lot of sense. What are the difference between the two schematics? Safety, efficiency, pros / cons?
« Reply #18 on: September 04, 2019, 05:59:54 pm »
Bump:
I am not asking for a scientific explanation, just a simple one, since one has a lot more components then the other but both should buck converters. :-)
Offline james_s
« Reply #19 on: September 04, 2019, 06:24:51 pm »
Buck converters do not provide isolation between line and load. Typically if you are going to go to the effort of making a off-line SMPS you may as well go with an isolated topology.
« Reply #20 on: September 04, 2019, 09:25:08 pm »
Great advice, Both of these do look like isolated, but are one better the the other?
« Last Edit: September 04, 2019, 09:27:29 pm by FriedMule »
Offline David Hess
  • DavidH
« Reply #21 on: September 04, 2019, 10:33:09 pm »
The reason for this, beyond galvanic isolation from input to output, is that the transformer adjusts the ratio of voltage to current in the power switch to a more advantageous value.  If a buck converter is used, then the power switch has to handle the maximum output current and the maximum input voltage making it significantly more expensive and lowering efficiency as well.  The transformer in a flyback or forward converter considerably reduces the current which the power switch must handle.
The following users thanked this post: james_s
« Reply #22 on: September 04, 2019, 11:33:42 pm »
Yes I see the logic in that and you do also, as written earlier" get added safety". What I am out to achieve is a 240V to 5V isolated smps. Since I have about no idea on what to do, I hope that some of you could point me to a schematic that is universally okay. I know that higher frequency is better but do also demand a lot more skills in designing the circuit board.
Offline MosherIV
« Reply #23 on: September 05, 2019, 06:54:53 am »
There is no one circuit that is universally ok, it depends on the parameters of the circuit.
Easiest is to find app notes for particular devices.
Building your own  :o
It is highly dangerous - there is rectified mains, HV DC, with all the power of your national grid behind it !
It is very difficult to find the isolation transformers. They are not easily available off  the shelf.
If you are doing this for learning, be very careful  :)
Offline BravoV
  • +++ ATH1
« Reply #24 on: September 05, 2019, 07:08:20 am »
Just because you could do & probably understand "buck converter" from say 12 V down to 5 V, it doesn't mean you can still to stick with buck converter ONLY to do mains 240V AC down to 5 V DC.
Go learn and study further other topologies as pointed by many posters above, that is not smart safe method of practicing electronics, especially related to mains voltage.
