Hello, I'm trying to build my own power supply for a soldering station, which has a power of 100W.
I've read a lot of literature, but some things remain unclear, so I'm writing here in the hope that someone can help. The requirements for this power supply are as follows:
Input voltage 180VAC-265VAC,
output voltage 24VDC and current from 0A to 4A, the station will dynamically draw current from the power supply, due to the fact that it has its own PWM regulator in it (that is, 4A current will be drawn from the power supply, then it rests for a while and some current is drawn again).
1. I'm wondering what topology to use for the power supply. I've settled on a few, for certain reasons.
a.) Forward convertor with 2 transistors-----this option is good in my opinion because it will withstand peaks from the network better and the stress on the transistors will be less. There are disadvantages here that this type requires a minimum load to work well and does not behave well with changes in the input voltage within wide limits.
b.) Flyback convertor------it is easier to implement, but there is more stress on the diode in the secondary and usually works in current mode control.
2. I wonder which control method would be better for my conditions (changes in the input voltage and changes in the load from 0A to 4A).
Can someone explain when it is better to use voltage control and when current control, that is, under what conditions is one method and the other more suitable, respectively?
Thanks.
