Hello guys, im trying to make a remote switch for an USB C device, but since the usb C connector has 4 V+ pins and many other ground and signal pins i was wondering if theres a way to switch ON and OFF many signals at the same time, ive a bluetooth micro controller that has many pins that i can use, but i wanted to avoid using 10 MOSFETS or so, im pretty sure thare are other ways, do u have any ideas/suggestions?
