Author Topic: SMPS LED bulbs dying running off dimmer switch  (Read 910 times)
Offline lordvader88Topic starter
« on: July 30, 2018, 09:56:29 am »
In a rental house someone has a dimmer switch for some of the mains 120V lights. And were using LED bulbs, and 1/2 of them stopped working. IDK if they used the dimmer or not.
I opened 1 up figuring a series LED fried, but they all work. There's some type of buck converter in there. I mapped it all out but to me the design seems very strange so far. There's 1 inductor that must be open, so maybe I found the problem.
In general tho none of the "eco" bulbs with a SMPS in the socket should ever be used with a dimmer switch right ?
I should tell the landlord either use incandescent's or take out the dimmer (since tenants can't be trusted with simple instructions like don't use the dimmer)
Online Zero999
  • 0999
Re: SMPS LED bulbs dying running off dimmer switch
« Reply #1 on: July 30, 2018, 10:30:22 am »
As a general rule, LED lamps cannot be used with a standard dimmer circuit. It can cause problems with flicker, damage to the lamps or dimmer circuit.
Special LED lamps which are designed to work with a standard dimmer circuit can be purchased, but they're more expensive and are slightly less efficient.
« Last Edit: July 30, 2018, 04:17:20 pm by Hero999 »
Offline JS
  • Country: ar
« Reply #2 on: July 31, 2018, 03:25:56 pm »
Yes, put a switch, incandescent or dimmerable lamps.
JS
If I don't know how it works, I prefer not to turn it on.
Offline james_s
« Reply #3 on: July 31, 2018, 04:40:06 pm »
My observation is that about 80% of the LED bulbs from reputable brands can be used on dimmers. Special LED rated dimmers are preferable but most will work to some degree on a standard dimmer. If in doubt, look at the package, it will say. I have lots of Philips, Cree and Feit LED bulbs that are dimmable.
