Author Topic: smps no output  (Read 282 times)
Offline ravi6545Topic starter
  • Country: in
smps no output
« on: March 21, 2024, 10:01:29 am »
I used TNY267 IC in my SMPS without connecting load the output is coming. but when i connect a load it's not working (it comes like ON and OFF). when i check PWM of the IC it shows fluctuating not constant signal. but i change the IC then also the same thing is coming so problem is not with a IC but only thing it doesn't give the correct PWM output. see the circuit attached.
Offline timenutgoblin
Re: smps no output
« Reply #1 on: March 21, 2024, 02:19:37 pm »
1N4007 rectifier diode is not suitable for 132kHz SMPS circuit. Try using 1N5819 or 1N5822 Schottky rectifier diode.
