Made by this instruction. Everything works, but windows 10 does not see the com port of this module
Don't miss what Michael said here:...
It's not very clear what you're schematic would look like, maybe try to draw it instead of describing it.
You need a microcontroller in between the UNI-T and the bluetooth module. Even though they're both RS232 it doesn't mean that you can just hook them up together. You need a micro that would take in the raw RS232 output of the UNI-T and wrap it in commands that the bluetooth module would understand.
Basically the bluetooth module can't make any sense of the UNI-T's output.
I did some experimentation with the UT61E+HC5 blue tooth module a couple of years back. I assume the issue would be the same with the HM10 you are attempting.
With the HC5 blue tooth, you need more than the Windows side to cooperate. The blue tooth module itself needs to do it's part. Hardware (circuits) alone is not going to do it.
UT61E is not capable of sending anything like pairing or initialization sequence to the blue tooth module. You have to work that in to your set up.
With the HC5, I can hook it up to the UniT cable's RS232 relatively easily (via dividers). But, I needed an additional TTL RX/TX input into the HC5, to first tell it to do 19200,n,8,1, set password, and to do pairing. Only then would another blue-tooth device such as the one in Windows find and pair with the HC5 to receive stuff from the UT61E.
Granted, you can setup your HC5 so that the defaults are right and the pairing already done. But when you want it to pair with another Windows machine or make any setup changes to your module, you need to hook up the alternate TTL input to the module again.
Eventually, my setup became UT61E->Arduino Nano->HC05, no longer simple and needs an extra power plug to power the Arduino+HC5.
In my case, it is that complication and the rare lost of communication due to other devices near by (such as moving my desk lamp too close) that prevented me in using BT. I didn't like the potential of loosing a night of work if I happen to put some other devices too close while logging.
I must say, while I ended up not using it, it was fun getting it to work.
