... the images. I tried to make them inline
The inline feature doesn't work on this forum. To insert inline pics, you have to post the message first (with its pics as attachements at the end), then edit your message again to add links to the now already posted images.
After hitting "Publish", go to your own post and click on one of the thumbnails to enlarge it. Once enlarged the pic, right click and "Copy Image Link" get the image URL.
Then edit your just published post, and paste the copied URL inside the text, but you have to put the URL between the img tags (press the binocular "Insert Image" icon from the edit-post icons-bar, then paste the image URL between the img tags). In text edit mode, it should look like this:
instead of
Now, the theory (including the ESR) says I should measure the following phase shown in the third image.
[attachimg=3]
This is close enough to the measurement that I would say the measurement is expected.
should become
[img]https://www.eevblog.com/forum/beginners/bode-plot-question-phase-response-of-passive-lp-filter-seems-odd/?action=dlattach;attach=1605499;image[/img]
and it will display like this:
By the way, thanks for the plots and the detailed explanation+measurements you posted, I found that very useful.
