Author Topic: Can someone explain what this gizmo is?  (Read 690 times)
Offline EasyGoing1Topic starter
« on: November 21, 2024, 01:44:12 pm »
Can someone tell me what this gizmo is on this ceramic heating element, and what it does?
(see attached image)
2442615-0
Offline PA0PBZ
Re: Can someone explain what this gizmo is?
« Reply #1 on: November 21, 2024, 01:56:07 pm »
Temperature switch, opens when a certain temperature is reached, it should be written on it.
Online themadhippy
« Reply #2 on: November 21, 2024, 01:56:46 pm »
looks like thermal switch,things get a bit warm it opens,when they cool down it closes
« Reply #3 on: November 21, 2024, 02:23:19 pm »
And is that temperature selected because if the heating element got hotter than that, it could be damaged?
Offline Zero999
  • 0999
« Reply #4 on: November 21, 2024, 02:37:25 pm »
It depends. There are three different types: auto-reset, manual-reset and non-resettable.
If it's auto-reset, then it might be used as a thermostat, in which case, if there's a risk of fire due to it overheating, there should also be a manual or non-resettable thermal fuse, which might be a different type.
It might be there in addition to a thermostat, in which case, it could any of the three types.
Offline Siwastaja
« Reply #5 on: November 21, 2024, 02:49:51 pm »
Or start a fire... Think about someone covering the heater with a cloth, or fan stopping due to failure (e.g. seized bearing).
This being said, it's a PTC heating element which already self-regulates to produce less heat when overheated, but this is an extra layer of safety (and possibly still pretty important, maybe the PTC still runs too hot when covered).
This is very likely a self-resetting one. But those have sometimes very large hysteresis so it might need to cool down a lot before it allows current to flow again.
Offline valcher
  • Country: ru
« Reply #6 on: November 21, 2024, 03:30:18 pm »
Offline BeBuLamar
« Reply #7 on: November 23, 2024, 08:29:05 pm »
Actually the heating element generally won't get damage but what houses the heating element may get damaged and causes fire.
