Author Topic: Fluke 196B TrueRms.  (Read 1146 times)
Offline Lachin012Topic starter
  • Country: tr
Fluke 196B TrueRms.
« on: November 21, 2022, 10:05:40 pm »
Hello. Please tell me if Fluke 196B has TrueRms measurement, I can’t find this function, tell me how to turn it on or how to set it up, thanks.
Offline bdunham7
Re: Fluke 196B TrueRms.
« Reply #1 on: November 21, 2022, 10:26:10 pm »
Using the multimeter ACV function, there is no separate setup--your readings will be TRMS.  Using the scope measurement functions, read the manual.  You will have TRMS, but the signal has to meet certain conditions on the screen to work properly.
The following users thanked this post: Lachin012
  • Country: tr
« Reply #2 on: November 22, 2022, 11:03:58 am »
Thanks for the reply. But I couldn't find the manual.
Offline alm
« Reply #3 on: November 22, 2022, 12:31:09 pm »
You can find the manual here: https://www.fluke.com/en-us/support/manuals
  • Country: tr
« Reply #4 on: November 22, 2022, 03:29:09 pm »
  • Country: tr
« Reply #5 on: November 22, 2022, 03:55:21 pm »
Please tell me, in the manual they write that version 196B does not have PWM measurement, but in the oscilloscope settings I see V pwm, I can’t understand please explain to me please.
  • Country: tr
« Reply #6 on: November 23, 2022, 10:10:53 am »
Doesn't anyone know?
Offline bdunham7
« Reply #7 on: November 23, 2022, 03:26:33 pm »
I don't even exactly know what the Vpwm (or is it VPWM) measurement is?  Nor do I have the 196B model.  However, Scopemeters in general often have different sets of measurements in scope and meter mode, so perhaps that explains the discrepancy--can you show more of the manual?  Or, perhaps the manual is wrong or the feature was added in a software update or ???
From a different Fluke Scopemeter manual:
Vpwm
Purpose................. to measure on pulse width modulated
signals, like motor drive inverter outputs
Principle .........readings show the effective voltage based
on the average value of samples over a
whole number of periods of the fundamental
frequency
Accuracy ............................ as Vrms for sinewave signals
And reading that I'm still not clear on exactly how Vpwm is calculated, but it appears to be an alternative to RMS, adjusting for the load being a motor rather than a heating element.
So feed your scope a PWM signal of some sort from an AWG, check the box to select that measurement and see if it gives you a reading.
  • Country: tr
« Reply #8 on: November 23, 2022, 04:23:15 pm »
Vpwm
frequency
Thank you for your answer, I will take some measurements and see what Vpwm is, maybe it looks like TRMS, something like an RMS measurement, I will write the result here.  I think you are right this feature Vpwm most likely added with the update.
on page 14 it is written about Vpwm.
« Last Edit: November 23, 2022, 04:50:27 pm by Lachin012 »
