Author Topic: Soft push button using latching switch  (Read 1085 times)
Offline jikoTopic starter
« on: July 08, 2019, 01:33:05 am »
I am planning to convert my wall switches to push buttons so I can use them in my smart-home system. I came across to EEVblog #262 - World's Simplest Soft Latching Power Switch Circuit, but I need to do the opposite. Is there a schematic that uses passive only components to convert a simple SPDT to a momentary push button?
Thank you for any input.
Edit: Every time the switch changes position an active high pulse of 3V and duration ~500 ms should be fired.
« Last Edit: July 09, 2019, 02:16:59 am by jiko »
Offline mikerj
Re: Soft push button using latching switch
« Reply #1 on: July 08, 2019, 09:09:34 am »
You need to describe how you want this to work, e.g. do you want a pulse of fixed duration every time the switch position is change changed, a pulse when moved to one position but not the other, do you want active low or active high pulse, what voltage etc..
Offline sokoloff
« Reply #2 on: July 08, 2019, 10:26:26 am »
Why restrict yourself to passives only? That rules out a whole bunch of solutions that may be beneficial.
Offline KL27x
« Reply #3 on: July 09, 2019, 01:56:12 am »
Sounds like a homework assignment.
The following users thanked this post: jiko
« Reply #4 on: July 09, 2019, 02:14:32 am »
Hi mikerj,
Thank you for your reply. Every time the switch changes position an active high pulse of 3V and duration ~500 ms should be fired.
Thanks
« Reply #5 on: July 09, 2019, 02:15:36 am »
You are right. Whatever solution that works.
