Hello, it has been sometime, ive posted, have to be more active
I was caught up a few years ago with thinking higher silver content wire ( brands like Stannol 4% silver high melting point). Long story short, some of my speakers the crossovers have had problems with cold joints and some of my audio gear.
I switched to 60/40, just the Jaycar (Australian store like Radio Shack), solder which i thought was good. I think went to 63.37 which i find is the best.
I came across an article about how silver is absorbed into the solder, and is mentioned here and elsewhere. I always scrape and clean traces back to copper before soldering. so i can get direct contact with the surface.
Another interesting thought is how gold plated surfaces like terminals - silver plated copper, would the same apply as to copper on a trace
I am relative new to Eutectic solder , why i thought this was the best place to post.
I did buy only a small sample of the 2% silver. I am wondering if i should get more or stick with the 63/37
Comparison - best joint maybe the 2nd from left the non silver wire, wire gauge used `16 awg silver plated copper on old pcb board
notice solder wire solidfied on the non silver wire
whereas with silver content wire is not solidfied
Depending on the wire, is it possible the solidified wire is less likely to be break? would some silver desolve into the contact on the board? i am just wondering
Thanks Sam aka Technics hifi fan
