Hey guys,
I'm putting together a little board so I can make simple SMD/SOIC prototypes without making a different board every time... one thought I had was to use 0805 resistor pads as either 0805 components or solder jumpers... the spacing between the two pads is around 25 mil / 0.65mm. What do you guys think, would this work or is the gap too big? Would there be some other issue with this method?
I've attached an image of the board so you can have a look... its set up to be used with or without a breadboard.
Thanks, Will
