Author Topic: Solder mixture - 60/40 67/37  (Read 2770 times)
Offline tkamiyaTopic starter
« on: January 18, 2020, 11:30:41 pm »
Although I've been in electronics for over 40 years, I never gave much thought to solders.  Now I'm wondering about something I'm sure many of you know....
Common lead-tin solder comes in 60/40 and 63/37 mixture.  What is the difference between the two.  Sure, melting point is a bit different by 5 degrees, but that's not much to make two different products.  There got to be more to it.
I've been using them interchangeably.  Can anyone share the secret?
Offline sleemanj
  • Professional tightwad.
Re: Solder mixture - 60/40 67/37
« Reply #1 on: January 18, 2020, 11:43:10 pm »
63/37 is eutectic, it melts and solidifies at a fairly precise temperature, in other words the transition from melted to solid happens much more quickly,  "melty...solid"  instead of 60/40 which is more "melty...a bit less melty... a little bit solid... getting pretty solid... ok we're done"
The following users thanked this post: tooki, Simon_RL
Offline Simon_RL
« Reply #2 on: January 19, 2020, 02:52:43 am »
So for noobs 60/40 is definitely the better option as it is more forgiving.
Offline Moshly
  • What's wrong with this thing
« Reply #3 on: January 19, 2020, 07:20:29 am »
Technically no, 60/40 has a longer time in the plastic (melty) state as its cooling down so the joint has to remain still for longer as you will get a dry joint if moved. For hobbyist it does not matter as you normally hold the part and watch the solder solidify before continuing.
Offline tooki
« Reply #4 on: January 19, 2020, 02:47:14 pm »
No, the exact opposite: 60/40’s plastic phase is a wider window of time during which the joint can be disturbed. This makes it LESS forgiving of movement during cooling.
60/40 is used because it is/was slightly cheaper, which mattered for mass production. But nowadays they usually cost the same, and IMHO there is no reason whatsoever to choose it over 63/37.
The following users thanked this post: Simon_RL
Offline tooki
« Reply #5 on: January 19, 2020, 02:55:27 pm »
IMHO, a modern hobbyist should have these three solders on hand, especially if they do repairs too:
1. 63/37 leaded, for most uses.
2. SAC305 lead-free, for when working on boards already made with lead-free.
3. 62/36/2 silver-bearing leaded, for when you don’t want lead-free, but are working on silver contacts, like the silvered contacts of old ceramic hybrids and many modern SMD components.
Under no circumstances should the lead-free be used on old boards originally made with leaded, since the boards may be damaged by the higher temperatures. Using leaded on originally lead-free boards doesn’t risk damage, but one should avoid blending the two kinds within one joint, since that results in a random alloy with unknown properties, meaning sucking off all the old solder before installing the new. (So IMHO it’s often just easier to stick with lead-free on such boards.)
« Reply #6 on: January 20, 2020, 11:22:57 pm »
Thanks everybody.  I'll stay with 63/37.
