Author Topic: Which companies license intellectual property for microcontrollers  (Read 3883 times)
Offline brucehoult
Re: Which companies license intellectual property for microcontrollers
« Reply #25 on: December 06, 2018, 12:18:58 am »
You can customise cores with various options here: https://www.sifive.com/core-designer
Coming soon, you'll be able to integrate a core or cores with a wide range of peripherals (both analogue and digital) to design a complete custom SoC yourself, online: https://www.sifive.com/chip-designer
Ahhh .. and the site is currently slashdotted.
Or, "Linused"
Offline ZeroResistanceTopic starter
« Reply #26 on: December 07, 2018, 03:45:02 pm »
Very high level. You only pick what components you want: CPU cores, IP blocks. It's the system's/SiFive's responsibility to make sure it works. The user does nothing about layout, nothing about electrical characteristics. More like some of the high level drag-and-drop FPGA tools, except it's for SoCs.
Ok! so as I understand it SiFive's Chip designer will also help in assembling the IP blocks for Analog peripherals like ADC / DAC? apart from the regular uC peripherals like counters/timers, capture/compare, DMA etc.
Offline brucehoult
« Reply #27 on: December 08, 2018, 01:41:55 am »
Yes, Chip Designer includes analogue/mixed signal IP blocks from several partners, including but not limited to SiFive acquisition Open-Silicon.
