Author Topic: Polyfuses and negative voltages  (Read 1716 times)
Offline seb1982Topic starter
« on: March 27, 2013, 02:05:37 pm »
Hi everyone!  :)
I'm having a complete brain fart!  Obviously, voltage is relative - that's like lesson one!
But I'm planning to use a 1.6A polyswitch in series on a positive voltage rail to protect it.  There's also a negative voltage rail as well as a ground.  Am I right in thinking that the polyswitch will work exactly the same on the negative voltage rail as it does on the positive?
I'm sorry for such a basic question, but I've tied my brain in knots by thinking about it too much!  |O
Smoking and melted? It was like that when I got here.
Offline c4757p
  • adieu
Re: Polyfuses and negative voltages
« Reply #1 on: March 27, 2013, 02:12:51 pm »
Yes.
« Reply #2 on: March 27, 2013, 09:27:45 pm »
Clear, concise and to the point!  ;D
Thanks.  :-+
Offline c4757p
  • adieu
« Reply #3 on: March 27, 2013, 09:35:10 pm »
A polyswitch is just a special thermistor, which is just a special resistor. And remember that the component doesn't care what ground is, it just cares what it sees applied to it. Applying -20, 0 across a resistor is just like applying 0, 20 across it - it just sees that one side is 20V higher than the other.
One thing to keep in mind is that you don't just need to block currents rail-ground, but also rail-rail. Many polyswitches have pretty low voltage ratings and many dual rail systems have pretty high voltages. Make sure it has a good safety margin around the total rail-rail voltage.
(Clarification: Ideally, if the fault current is rail-rail, both polyswitches will trip and share the blocking voltage. They are resistors, after all, even when tripped. I don't like to count on that, though.)
« Last Edit: March 27, 2013, 09:40:05 pm by c4757p »
