Electronics => Beginners => Topic started by: henryd99 on September 14, 2013, 09:13:05 pm
Title: Soldering iron question
Post by: henryd99 on September 14, 2013, 09:13:05 pm
Hi i am new to the forum i am 14 years old and i am looking to buy a soldering iron and i really don't have very much info i have to spend under 40 bucks so if you could give me some info it would be appreciated thanks
Title: Re: Soldering iron question
Post by: snipersquad100 on September 14, 2013, 09:16:03 pm
Just try and get a temp controlled iron, not those cheep constant on ones.
Post by: henryd99 on September 14, 2013, 09:24:21 pm
so any temp controlled will work
Post by: snipersquad100 on September 14, 2013, 09:29:40 pm
The best you can afford. Mine was £60 from Maplin and I cant fault it. I've had it 6 months and never changed the tip yet.
Post by: henryd99 on September 14, 2013, 09:31:07 pm
thanks for the info but would you think its a bad idea to just stick with a conical tip or get a screwdriver tip
Post by: IanB on September 14, 2013, 09:52:58 pm
It's best to avoid the tiny pointy tips. A medium screwdriver tip or a horseshoe tip (conical shape with a flat section at the end) works best. The reason is you want a good contact area to conduct heat from the tip to the job. Tiny, pointy soldering tips are bad at this. You will end up holding the iron in place for longer while waiting for the joint to get hot enough, the flux will dry up and stop working, and the parts may be damaged. The ideal solder joint is completed in 1 or 2 seconds.
Post by: henryd99 on September 14, 2013, 11:21:14 pm
ok thanks
Post by: nanofrog on September 14, 2013, 11:26:28 pm
Here's a few that might be of interest...
Used: http://www.ebay.com/itm/Antex-TCSU1-Soldering-Station-Controller-with-Pen-/171124139624?pt=LH_DefaultDomain_0&hash=item27d7cb2668 (http://www.ebay.com/itm/Antex-TCSU1-Soldering-Station-Controller-with-Pen-/171124139624?pt=LH_DefaultDomain_0&hash=item27d7cb2668) Tips are still available (~$6.00 per on Amazon; sticker on the back photo tells the compatible tips & their temps at each setting).
Used: http://www.ebay.com/itm/CSI-2900-SOLDERING-STATION-/130954701467?pt=LH_DefaultDomain_0&hash=item1e7d822a9b#ht_6028wt_1254 (http://www.ebay.com/itm/CSI-2900-SOLDERING-STATION-/130954701467?pt=LH_DefaultDomain_0&hash=item1e7d822a9b#ht_6028wt_1254) Needs a holder. Tips include heating elements & sensors, so they're a bit more expensive (~$12 per).
http://www.ebay.com/itm/936B-ESD-Iron-Soldering-Station-SMD-Desolder-Welder-Welding-w-Stand-Sponge-1-Tip-/390635897189?pt=LH_DefaultDomain_0&hash=item5af3b6c165 (http://www.ebay.com/itm/936B-ESD-Iron-Soldering-Station-SMD-Desolder-Welder-Welding-w-Stand-Sponge-1-Tip-/390635897189?pt=LH_DefaultDomain_0&hash=item5af3b6c165)
http://www.ebay.com/itm/Mini-Soldering-Station-BK-938-Welding-Equipment-Soldering-iron-tool-Station-/271168235577?pt=LH_DefaultDomain_0&hash=item3f22e2e839#ht_7009wt_1399 (http://www.ebay.com/itm/Mini-Soldering-Station-BK-938-Welding-Equipment-Soldering-iron-tool-Station-/271168235577?pt=LH_DefaultDomain_0&hash=item3f22e2e839#ht_7009wt_1399) Tell the seller the input voltage.
Post by: henryd99 on September 14, 2013, 11:32:52 pm
thank you I just bought one
Post by: nanofrog on September 14, 2013, 11:43:59 pm
What did you decide on?
FWIW, if it's a Chinese unit, you might want to take a look inside before using it to be sure there aren't any safety issues (i.e. hot or neutral tied to the chassis ground). There are threads on this, as a few members have had such issues, but usually a very easy fix.
Good luck, and enjoy.  :)
Post by: henryd99 on September 14, 2013, 11:45:57 pm
Thanks i bought a yihua 936 its a knock off of the hakko 936 but it has some pretty good reviews and it has a thirty day return policy so if its not up to par i can just send it back
Post by: nanofrog on September 14, 2013, 11:52:48 pm
That works too.   8)
FWIW though, fixing it yourself can save you the return shipping if it's something you can tackle.  ;) And you get to practice your skills/learn by doing.  ;D
Post by: henryd99 on September 15, 2013, 12:00:28 am
Thanks thats a good idea ill see what i can do
Post by: amyk on September 15, 2013, 09:50:19 am
That works too.   8)
That is, if you have another soldering iron to fix the broken one :D
If it's the Yihua that's around $15, definitely buy another one for spares. They're based on a dead-simple analogue controller (a simplification of the Hakko one) and there's not much to go wrong with them, but you never know...
Post by: henryd99 on September 15, 2013, 10:30:03 pm
yeah that's the one i bought
