Yes, in a phase diagram, it’d be most accurately called a plastic region. Don’t confuse “lax” or “confused” with the understanding that a scientifically precise usage and an everyday usage of a word aren’t the same thing. You will never win someone over by denying or rejecting the existence of the everyday usage, or by calling out someone choosing to use it.
So, what has this thread gained by your tirade on this issue? Nothing. You’ve flexed your brain nuts, we get this. So what? All you accomplished was to bury the actual point I was making to tkamiya. So thanks for that...
I admitted
up front, and made it
quite explicit I was being pedantic, and quite obviously it was done to attempt to add some precision to what you were saying.
That you choose to treat what I've said as, and I quote, "a tirade" is entirely down to you. You were the one who chose to tell me "
You are being pedantic for sure, but you’re also wrong", (did you really expect that not to garner a response) without that I'd have had nothing more to say on the subject and I
did stick to the subject, I didn't start attacking you. It would appear to be your desire to be seen as 'the most right' and/or 'the most knowledgable' that pushed this on, and when you're finally proved wrong you start blaming me for derailing the thread and using the word "
tirade". Look it up in the dictionary
*, for a linguist you've a poor grasp on the word's meaning as it's quite clear that what I've had to say isn't a tirade, angry by definition . Either that or you are deliberately misrepresenting my behaviour in an attempt to be provocative.
Note that you are the one who has shifted from discussion of the matter at hand, the properties of solder, to attacking my behaviour. You're adding heat, but no light, to the conversation. With all that in mind, I don't intend to engage you any further on the subject beyond this defence of myself, lest I too become guilty of the same. Knowledgeable of my own weaknesses, in particular that I'm likely to pointlessly respond to you if you continue your diatribe, I'm hitting the 'ignore thread' button.
* tirade | tʌɪˈreɪd, tɪˈreɪd |
noun
a long, angry speech of criticism or accusation: a tirade of abuse.
ORIGIN
early 19th century: from French, literally ‘long speech’, from Italian tirata ‘volley’, from tirare ‘to pull’.
