just pondering ...
the whole purpose of using SMD is to save space (or maximize it)
as SMD values increase (ie capacitor farads) ... the size also increase definately ...
eg : 1206 commonly used ... goes up to about approx 10uF 50v. somewhere, you need to cross over into either something like giant 2220(5650) or SMD cans (2.2mm diam onwards)
in order to save space ... has anyone actually tried to layout your SMD ... ON ITS SIDE ? ... so practically, the pads are kind of reduced by somewhat 33% - 50% ? this is especially the case for 2220 example, on its side, it actually saves about 2mm (assuming 5mm width now becomes 2.5-3mm thick) ... which seems alot if you are packing a tight board.
this would of course be rather impossible for pick and place
comments please
