I don't think ultrasonic equipment would be justified, but thanks, the technology looks interesting.
The crud on the soldering iron from that specific flux was not your everyday crud. I spent about half an hour getting it off my tip using brass wool and it was never the same again.
Unfortunately I don't have any lead free stuff on hand. I might look into getting some.
Yeah, brazing stuff is based on boric acid, but it's got something else in it too. In any case, activation temperature for this particular flux is way too high for this application.
The crossection of track is comparable to some thicker wires, thermal mass should not be the issue. I've soldered thicker copper wires without much problem.
I have the Weller PU 81 station and WSP 80 iron. It's 80W, so should be good enough. The tip is a 2,5mm chisel.
All in all, yesterday, I tried with Copper Sulphate, but had no luck. Decide to give it another go and leave the crystals to dissolve overnight. Today, I left a drop of it on the rail for some 20 minutes (I got distracted by other stuff) and after that the solder made a good bond (stronger than a 0,14mm^2 copper wire, which is good enough for me).
Thank you, Ian (and the rest of you guys)!
