Psi, yeah, I guess I didn't think that thru.
Jwillis, the way I would do it there is no relay.
Sleep temperature is achieved the same way regular operating temperature is achieved. It's like you are turning the knob on the station down and back up. The station already has the circuitry to react to that.
There's no need to use a relay. The station already has a triac in there to switch the heater via a temperature controlled circuit. You just have to change the set temp to an alternate setting.
If you have a Space Shuttle in front of you, and you want to rig it to launch at 10 oclock, you hook an alarm clock to the Launch Button that has already been designed into the billion dollar vehicle. You don't jury rig a match to go off under the booster.
