1 Mohm represents a huge load? In some circuits 10 Mohm might represent a huge load, in other circuits 20 kOhm/V is acceptable. Most circuits have a fairly low impedance these days, especially compared to the tube days. Common resistors are in the 100 ohm - 10 kOhm order of magnitude, so 1 Mohm should be quite acceptable. 1 Mohm may be an issue if you want to use a high voltage probe, since many are designed for a 10 Mohm load, but I wouldn't want this meter anywhere near high voltage anywayi. No doubt it's cheap junk, what do you expect for $5? I wouldn't expect it to be very accurate either, especially if the battery is low. That doesn't make it completely useless, though. Until it dies, it will probably be fine for distinguishing 1 kOhm and 10 kOhm resistors. Or short circuit vs. open circuit. Or 5V vs. 9V. Does high DCV accuracy really matter if it's a power supply for a digital circuit that accepts 4.5-5.5V? Just don't use it for anything high-voltage or mains related, or where a correct measurement is important.
