Electronics => Beginners => Topic started by: zeeawk on August 05, 2016, 09:18:06 pm
Title: soldering tip for smd work
Post by: zeeawk on August 05, 2016, 09:18:06 pm
What would be the best tip to get to practice smd work?
I have a weller wes51.
Title: Re: soldering tip for smd work
Post by: RobertHolcombe on August 05, 2016, 11:06:39 pm
Ideal tip size will depend on component size and board density.
The ET series tips for the WES51 isn't very divers being only conical, chisel and hoof style. The ETA is a 1.6mm wide chisel tip, that would be my choice for general SMD use.
Post by: eKretz on August 06, 2016, 04:56:24 am
Personally I've found that any small tip will do quite well as long as enough flux is used. I don't have a Weller, my iron is an Ersa, but for stuff like tiny SMD caps or SOT-23 BJTs etc. all the smaller tips give perfect results as long as enough flux is present. I tend to use an offset pencil tip most of the time for smaller stuff just because it makes easier to get into tight areas.
Post by: zeeawk on August 07, 2016, 07:32:30 pm
Thanks... I've ordered a couple different ones and ill give them a go.
