Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
0603 resistor pad smaller than physical resistor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 0603 resistor pad smaller than physical resistor (Read 1474 times)
DroneBuster
Contributor
Country:
on:
July 05, 2016, 07:41:52 pm »
Is it normal that high density pads are narrower than resistor (footprints generated with Altium IPC compliant footprint wizard)
Pictures attached
Logged
Christe4nM
Supporter
Country:
Re: 0603 resistor pad smaller than physical resistor
Reply #1 on:
July 06, 2016, 07:47:54 am »
No that seems wrong to me. The pad must be at least as wide as the terminal. If I remember correctly, a tiny bit wider even for IPC "least" (i.e. high density) footprints.
A quick search gave me this IPC calculator at their official site, it might help:
http://www.ipc.org/ContentPage.aspx?pageid=Land-Pattern-Calculator
But do check if you entered the right dimensions into Altium's calculator. And also check if your 3D body has the right dimensions. Just to make sure you're not chasing the wrong error
Last Edit: July 06, 2016, 07:52:17 am by Christe4nM
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #2 on:
July 06, 2016, 09:36:18 am »
Side fillet can be -0.03mm.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
