Greetings Lord Vader !
One thing that is really useful is a "wolfcraft" drill vise , this has a slight recess in the jaws and holds PCB's perfectly , it also has a quick release feature. (red knob) , There are also horizontal and vertical grooves in the jaws so you can hold round things. You can get it at some Hardware stores and hobby/model making suppliers.
The other thing I made is an "operating table" , it's 160mm x 210mm , and the top is 70mm from the desk , its just a bit of chipboard, with a big lump of cast iron screwed to the bottom (made from two bits of junk I found in the shed), it's important to get a bit of weight in this so it doesn't skid around or tip over. It positions the PCB just right so your hands are in a comfortable position. You can spin it around easy, and attach foldback clips to hold wires etc. So you can solder THT , and SMD , and use a hot air gun too.
There's a little platform that goes over the table, with about 6mm clearance over the PCB, this is helpful with SMD loading as you can lean on the platform/ put SMD parts on it, There are a couple of bits of glass fibre tape on the top, these are useful for flipping SMD resistors etc up the right way. There are some little trays in there too to hold assorted SMD parts .
