Personally, I only preferentially use stranded wire when the two ends are not fixed in relation to each other. And in this scenario, the joints will either be crimped or they will need some kind of strain relief or isolation from where the rest of the wire is free to move.
For connections that are going to be simply soldered with no strain relief between two points that fixed in relation to each other, I usually prefer solid wire with a thin/flexible insulation. It is more ductile for the gauge, meaning it tends to stay better where you bend it. And it is LESS prone to breakage when occasionally moved for maintenance, under these conditions of being soldered without strain relief. Stranded tends to break next to the joint in this scenario. The sharp transition between solid solder and free strands is not kind.
Stranded will be preferred in case of using crimp connectors made for it, of course.
