What inspired this interest?
What kinds of materials do you have in mind?
Anyway I think it is impossible. Water has very high thermal conductivity. So anything touching water even if it generates heat all by itself will efficiently and quickly transfer heat to the water it is touching, and quickly the nearby warmed water will transfer heat toooo the rest of the water. Similarly the container that is filled with water will quickly transfer heat from the water touching the walls of the container inside and out through the walls.
So you cannot have a significant temperature differential between the inner item and the inner water or the outer water that remains effective withouttttt (a) a lot of extra heat input to compensate for the rapid heating of the water (and it cooling the item correspondingly) and (b) the transfer of heat out into the environment.
Take a pebble, heat it to X temperature above ambient, say by placing it into a pot of boiling water.
Remove the hot pebblle and drop it into a container of cool water.
Notice that within a very short time the pebble has drastically cooled and the water has correspondingly warmed.
And that is with a high thermal mass / high specific heat object like rock that also has not so high thermal conductivity relative to volume.
So..yeah..no. Not going to effectively happen optically unless you want to go buy an expensive apparatus that can deposit a lot offff heat in a little time and even if you did, I wouldn't want to be around when you played with it. Eek.
catalinawow, you wouldn't happen to have some info on this would you? I had no idea eye safety would be an issue on these things so I would've for sure messed myself up on it. Any links would do (not TOO technical if possible. I can go through the more technical stuff but it's slow going).
At present I'm trying to heat a small item (can be any material frankly as long as it's small) inside a water filled container inside a water filled pot. I was planning on sealing all items but now I'm concerned about reflections off the glass.
