So I have a Sony TA-FB930R that I replaced one output MOSFET on. The manual says that the test point for both channels (warmed up, no signal, no load) should be ±10mv. On the left channel, I can do that just fine. But even riding the amp hard for 10m (50% load through power resistors), I can't get the reading to go higher than 6.5mV or thereabouts. I figure "can't set it high enough" is better than the opposite, but....
Now the question is whether a) that's a problem that needs solving and b) if so, how to solve it. I haven't done THD measurement since I don't own that kinda gear.
My good Mexican friend Service Manuel is attached.
