Author Topic: sound analyzer for automating quality checks?  (Read 6393 times)
Offline engineheatTopic starter
Re: sound analyzer for automating quality checks?
« Reply #25 on: January 16, 2019, 01:20:21 pm »
How much tolerance do you have for serious mathematics?  You don't need to actually learn the details anymore than you need to learn the details to do an FFT, but you will need to not run away in fear.
I have decent mathematical background, however, I hope to use a method that's more easily explained to people. A black box approach will not help this get adopted.
Can we use some more traditional machine learning method like regression, support vector machine etc, or decision tree? Just need a handful of good attributes to use. I don't have a ton of data (sample motors) at this point anyway.
Thanks
Offline rhb
« Reply #26 on: January 16, 2019, 03:22:29 pm »
This is work done in 2004.  It's also very easy to explain accurately in a non-mathematical manner.  I have no idea what "deep learning" is.  A friend has been doing a lot of work with support vector machines, but personally I know nothing about them.  I could go into a long essay about the problems with neural nets, etc, but it's really pointless.
The following description assumes that you can run the motors individually at different speeds during the test. If that's not the case then you'll need to omit the part about identification of the bad motor in the assembly.
"We have collected sample recordings of good motors and bad motors and put them in a  dictionary of motor recordings.  As we identify new quality control issues we add them to the dictionary.
When a motor is tested, the 4 sample recordings which best match the motor being tested are selected.  If any of those samples was taken from a defective motor, the assembly is diverted for rework. along with the identification of which motor in the assembly is defective."
That's an easy concept to grasp and is an accurate description.  The mathematical proof that the result is correct is the part that's hard.
Read the introduction to this paper.  It's an excellent introduction to the field.
https://statistics.stanford.edu/research/most-large-underdetermined-systems-linear-equations-minimal-l1-norm-solution-also-sparsest
Offline MasterT
« Reply #27 on: January 16, 2019, 03:44:15 pm »
Reminds me "voice recognition" project, I've done once with arduino AtMega32u4. Not in any way an expert in the field, my thoughts were simple, having  FFT "waterfall" - picture, so all bla-bla math boils down to pattern recognition in the image.
There is excellent book: http://101science.com/dsp.htm
We will demonstrate FFT convolution with an example, an algorithm to locate
a predetermined pattern in an image.
http://www.dspguide.com/ch24/6.htm
Arduino easily recognized single word commands (memory limits put constrain 1 sec.), so I had a difficulty  to pronounce the same word twice with 80% match.
  There was no problem if my computer says "Speaker Test" twice - result was better than 96%.
« Last Edit: January 16, 2019, 03:46:30 pm by MasterT »
Offline rhb
« Reply #28 on: January 16, 2019, 04:25:52 pm »
I had some concerns when I read that, but a quick skim of the link showed that it was doing things properly.  That is the 1940's Norbert Wiener approach.  Still perfectly valid and useful, but not as powerful as a sparse L1 pursuit.  The reason being that it's L2 (least squared error).  But until recently L2 was all one could afford computationally and even that was often a strain on a VAX 11/780.  An L2 solution smears the result which L1 does not do.
However, you can get close to an L1 using reweighted least squares or using singular value decomposition and truncating the eigenspectrum of a Karhunen-Loeve Transform (KLT).  The latter was my tool of choice for problems like this until 2013 when I learned of the work by Donoho and Candes.
What brought their work to my attention was when I realized that basis pursuit following the description in  Mallat's 3rd ed was doing things I *knew* based on many years of using the SVD-KLT approach were impossible.  As I had almost 30 years experience with SVD-KLT, that *really* got my attention.  SVD-KLT is very powerful in good hands.
« Reply #29 on: January 17, 2019, 12:55:28 am »
Thanks, you've been very helpful. I made lots of progress on this.
I guess another quick question is that I used a sample rate of 44100 hz, but each frame is 1024 (or 2048 in another version). This means my frequency resolution will not be a integer. Is that a problem? Should I use a sample rate that is a multiple of the frame size?
Offline rhb
« Reply #30 on: January 17, 2019, 02:19:10 am »
Makes no difference at all.  The short time series smears the spectrum quite a lot.
I'm very pleased and impressed with the progress you've made.  This is pretty standard stuff, but it's not trivial and as you now know is a significant amount of work.  Your employer is lucky to have you.
As you are automating what is currently a manual procedure I'd like to suggest that you start out using a graph of the DUT spectrum with limit lines or a simple waterfall display on a monitor in portrait mode showing the spectra for each device.  Have a human make the send to rework decision.  Get some experience with that before implementing  SVD-KL or basis pursuit.
My reason for suggesting this is the graphical displays will make it easy for everyone to understand what you are doing when you automate the last step.
Offline MasterT
« Reply #31 on: January 17, 2019, 02:43:45 am »
After reading this vocabulary, I understand why "Mad Cow" disease outbreaks happened.
Lucky that mathematics was invented long before patent layers were born.
Offline rhb
« Reply #32 on: January 17, 2019, 04:28:06 am »
It's far worse than you can imagine.  The same mathematics appears with a dozen names in the literature.  I've lost count of how many times I've spent several days investigating some "new" algorithm only to find that it was just someone reinventing the wheel.
I go to considerable trouble to try to restrict myself to what appears to be the mainstream lexicon.  But if you span lots of disciplines as I do, it eventually makes you crazy.  What I wrote is actually *very* generic.  But I feel obliged to define things like L0, L1 and L2 norms so that non-mathematicians have some idea of what I'm saying.  I hate it when someone uses a dozen acronyms without defining them.
If you think this was bad, look at  "A Mathematical Introduction to Compressive Sensing" by Foucart and Rauhut.  It was written for mathematicians and the jargon is incredibly opaque.  "A Wavelet Tour of Signal Processing" by Mallat is almost as bad.
I'm 65.  My undergraduate degree was in English literature.  My MS was in geology.  So the fact that I spent 3 years reading F&R twice and Mallat once plus about 1500 pages of original papers in mathematics rather boggles my mind.  But it was a lot of fun.  I just wish I could find someone else that I could talk to about it.
Offline MasterT
« Reply #33 on: January 17, 2019, 04:55:39 am »
I always thought, that man should be proud of what he had done, or what he invented.
Not for what he  had read, and able to "parrot"-ed on a forum, where nobody would understand what he is talking about.
No offence mean, just non native eng. person with post brain wash traumatic disorder.
Offline rhb
« Reply #34 on: January 17, 2019, 02:35:21 pm »
Learning is the most important accomplishment in life.  I read 3000+ pages over 3 years and I can explain what it is, why it works and how to do it in simple English.  F&R proved so difficult  on first reading I had to read Mallat and then reread F&R.  F&R is 600 pages; Mallat is 800. But even after that it was still unclear.  It was not until I read the original papers by Candes, Donoho and their students and made a foray into the geometry of N dimensional space that I reached the point I understood.  I worked as a research scientist/programmer in the oil industry with some of the very best people in the field.
Nothing I have done compares with the difficulty of learning what I refer to as  "sparse L1 pursuits".
Application include:
compressive sensing (single pixel camera and MRI video)
passive radar (locate other airplanes using only the ambient RF field so that you do not reveal your presence)
matrix completion (the Netflix prize solution)
blind source separation (isolate  any speaker at a cocktail party with a few microphones randomly placed)
statistics and machine learning (far too many buzz words to list)
error correction (detect signals below the noise floor)
genetics (identify the alleles in DNA that cause an inherited trait)
There are more, but they involve really exotic mathematics and are primarily of interest to mathematicians rather than engineers and scientists.
My references to Wiener, SVD-KL, etc  were for the sake of tying to the formal education in mathematics which most engineers receive, albeit without sufficient exercise to fully comprehend until graduate school.  That is all basic DSP.   The attached figure is why sparse L1 pursuits are so different and important.  The explanation will mean nothing if you do not understand Shannon-Nyquist sampling theory.
Upper left figure is the Fourier spectrum of an arbitrary waveform.  Below it is the time domain waveform with 16 samples randomly selected from the 64 samples.  The plot is drawn with the usual sin(x)/x interpolation between points as done on a DSO.
At the top right is the result of attempting to recover the Fourier spectrum from 16 samples using an L2 norm inverse.  The bottom right is the result of doing the same thing except using an L1 norm.  In both cases Ax=y is being inverted to recover the Fourier coefficients in x.  The FFT solves the same problem via L2 under Shannon-Nyquist sampling constraints.  Shannon still applies in the L1 solution.  Zeros don't convey information.
That is the biggest advance in signal processing since Wiener's work in the 1940's.  All DSP that does not have "wavelet" attached to it is based on Wiener's work.  That's most of the DSP I've seen done in 37 years of doing it, mostly in major oil company research and technical services departments.
Offline MasterT
« Reply #35 on: January 17, 2019, 05:15:27 pm »
KGB used the books to "program" a human-beans into "android-alike" robots.
Than NLP - Neuro-Linguistic Programming become very popular.
Some poor guys never realize they were robots all theirs miserable lives.
I'm saying this to warn "not to read" any crap you may find in the library or on the internet. It may and will be used against you.
Offline rhb
« Reply #36 on: January 17, 2019, 06:19:20 pm »
Humans have been programmed since they first appeared on the planet.  It's called child rearing.  Unfortunately most of the parents of the 20 something generation didn't actually do that they left it to Mr. Rogers, Sesame Street and the rest of the crap on TV.
Most people are robots but don't realize it and would vehemently deny it.
None of this has anything to do with this thread or with electronics or technology in general.  So please take it elsewhere.
Offline rhb
« Reply #37 on: January 17, 2019, 07:22:38 pm »
I had an interesting insight into the ambient noise problem when I went to bed last night.  I don't know why, but this is a common occurrence. I think it's because I take my brain out of gear and just let it idle.
There are three sensible approaches to the problem:
1)  Subtract an average ambient noise spectrum from the result.  That works OK if the noise characteristics are time invariant.
2)  Use  number of ambient noise spectra in an SVD-KL decomposition.  That will work quite well, but doesn't provide very good separation between device noise and ambient noise.
3) Use a large number of ambient noise spectra collected over several days and place them in the dictionary for a basis pursuit.  Increase the allowed number of non-zero coefficients in x from 4 to 5, the 4 gear trains and the ambient noise.
The last of these is sufficiently advanced to qualify as an MS thesis topic anywhere.  Probably not quite PhD dissertation topic grade in mathematics at a first rank school, but close.  And very likely it would qualify at Stanford levels for a PhD in Industrial Engineering and statistical process control.
The fundamental L0 problem is NP-hard.  It's the classic combinatorial problem.  The optimal answer requires evaluating the residual error for every cobination of 5 vectors drawn from a set of 10,000 or more. The really big deal about the L0-L1 equivalence paper by Donoho that I cited earlier is that Donoho proved that *if and only if* you get a sparse result using an L1 norm, it is the L0 norm optimal result.  He has also shown by arguments from convexity in N dimensional space that you are overwhelmingly likely to get an answer. The GLPK solver can make the selection of vectors from a set of 50,000 in L1 time,  though not in 1 second.
However, Donoho later presented a solution technique drawn from the theory of regular polytopes in N dimensional space which I *think* is trivially parallel.  And work on the MRI video problem has led to other work on fast solutions.  I've not read any of the literature published since 2015-2016, so I don't know the current state of the art.
Offline MasterT
« Reply #38 on: January 17, 2019, 09:28:58 pm »
I'm perfectly aware of censorship that each my post goes through,  and don't feel a joy to talk with AI or retarded. So really don't care about the membership.
But I did a quick research on the obsession someone has with a book. Using search box in the upper right corner of this page:
1. Word "Donoho" was referenced 23 times by he same poster.
2. Word "Mallat" --//--     11 times just for last year.
Is it right time  to visit a doctor?
Offline rhb
« Reply #39 on: January 17, 2019, 10:46:13 pm »
Absolutely, you should make an appointment with a dementia specialist as soon as possible.
Offline MasterT
« Reply #40 on: January 17, 2019, 11:19:13 pm »
I did with a psychiatrist, they  told me it's " schizo paranoia ".
This liberates me to disclose any confidential files, that well above your clearance, Parrot.
« Reply #41 on: January 23, 2019, 06:09:57 pm »
Thanks, this is what I was thinking about as well, will give it a try.
The test station is in an enclosure where it's mostly isolated from outside noise. However, inside the same enclosure, there is another mechanism down the line that creates noise. However, the noise for the other mechanism is predictable and is "in sync" with my recording interval. So for example, after 1 second into my recording, the same noise (mechanism) will occur. I guess averaging the noise FFT across the recording length and subtracting it should work decent in this case right?
As a 2nd question, when we think of "decibels" we think in terms of loudness of sound without regard to frequencies. So when they said a jet engine is at certain decibel, they are not breaking it down to frequencies. So what is a correct way to interpret decibel? The total power of the FFT spectrum added together? Are there any device that can measure the "decibel" of a sound and output a single number?
Thanks
Offline rhb
« Reply #42 on: January 23, 2019, 10:15:24 pm »
Sound level meters have weighting functions which are designed to match the sensitivity of the human ear.  For example, "A" weighting is a common choice.  so the single number is a weighted average.  That's not appropriate for this problem.
In your case taking the log of the amplitude at each frequency will prevent a few strong frequencies from using up all your dynamic range.
You'll have to experiment at this point.  I'd start by taking a long recording of the noise, breaking it up into say 1000 segments the same length as you are using to check the motors and use that.  While you're at it, in addition to the mean at each frequency, compute the standard deviation.
To start with I would not do the subtraction.  I'd plot the mean and upper and lower 1st and 2nd sigma for the noise data and the same for a long recording of a "golden" reference motor assembly with the noise present.
That way, if the noise goes outside the normal bounds, it will alert the operator.  If a sample goes outside the 2nd sigma bounds on the golden reference you've got a problem motor.  I'd test this for a while in parallel with the existing line operation to get a feel for the issues that might arise.  While this is not very sophisticated relative to the other solutions I mentioned, it's also not trivial.  You are very likely to get some surprises.  Once you have data and can make plots with gnuplot, please post them so I can look at them,
I don't know your age or circumstances, so I can't say whether doing an MS or PhD in industrial engineering makes sense for you.  However, implementing the basis pursuit and submitting a  paper describing it in a professional society journal would become an important and highly cited paper even if someone has done something with basis pursuit already.  Even without additional educational credentials, that means more job opportunities and money.
The basis pursuit is no more difficult than what you have already done.  It's a little more work as there's new software to learn, but I can help you with that by supplying some example cases to play with.  Once you've got it set up it would only require modification if the noise environment changed or the assembly design changed.
I don't recall if I mentioned it in this thread, but I'm a retired oil industry research scientist/programmer.   I worked for three majors, a super major and two large independents.
As a contractor I routinely attended industry consortia on behalf of the client at Stanford and other top schools in my field.  So I was grilling students and professors on the work they were presenting.  It's *very* unusual for a contractor to do that.  An all expense paid trip to Palo Alto or the Stanley Hotel in Estes Park (where "The Shining" was filmed) is rather a plum assignment.  But I was the last person left after a couple of rounds of "right sizing" who knew enough to do it.  Generally I knew about 1/2 the attendees either from working with them at other oil companies or from the annual professional society meetings.
I think it worth noting I did not gt my PhD, personality conflicts with my supervisor led to losing my financial support after 4 years.  So I'd have had to go to Stanford and spend another 6 years.  Losing another 6 years of income living on a grad student stipend was simply too costly.  It did prevent my getting jobs where they wanted a PhD to impress the customer, but otherwise had no effect on my earnings or status at work.  Most people assumed I had it and were very surprised when i said I didn't.  At the PhD level, normal introductory small talk includes inquiring where and under whom someone took their degree.  In the case of major consortia such as the Stanford Exploration Project founded  by Jon Claerbout and now run by his student Biondo Biondi which has run for 45 years, they will also ask when.  That tells them who your classmates were and the work with which you are familiar.
I'm not an industrial engineer, so I can't say how much attention sparse L1 pursuits have attracted in that field, but there are two active research consortia in geophysics entirely devoted to the subject.  One at U of BC in Vancouver led by Felix Hermann and the other at Alberta  led by Mauricio Sacchi.
If you're not familiar with industrial research consortia, these are organizations that the big name professors use to raise money to fund their graduate students.  Typical fee is $35-55K/yr.  For this you get access to the research a couple of years before non-members.  In many cases the software is only available to members even after 5-10 years.  You also get access to the students and if you pick up the phone and call the professor, he takes your call.  He'll also come do a day long short course if requested.
I took a quick look at Mallat, but I don't think I could post a long enough scan to be useful.  But I have posted a figure from "A Mathematical Introduction to Compressive Sensing" by Foucart and Rauhut.
The upper left shows  the amplitude of the Fourier coefficients for the time domain trace show below it.  From the 64 points in the inverse transform of the upper left, 16 were chosen at random.    Only the points chosen are marked and a sin(x)/x interpolator has been applied to the 64 samples generated by doing the inverse transform of the FFT in the upper left.
The upper right is the result of attempting to recover the amplitude coefficients from the 16 samples shown in the lower left using an L2 solution of Ax=y.  The lower right is the result of solving the same problem using an L1 norm instead.  The Nyquist criterion would require all 64 samples to recover the amplitudes using L2.  But the L1 case only Shannon applies.  A sine wave can be fully described by 3 samples.  Shannon showed that  we *must* have at least 15 samples to convey the information.  In the case of a sparse L1 pursuit the bound is a little higher and 16 samples are needed.  But that is 1/4th of the number of samples that the Nyquist criterion requires.  So that represents a substantial reduction in the time required to acquire the data.
Mallat also treats the problem of removing additive noise, which is why it's too big to post a scan.
On the surface this is very different from your problem, but the underlying mathematics are like a magician's bag which changes color every time he turns it inside out.
« Reply #43 on: January 24, 2019, 03:08:37 am »
I got a Masters in Computer Engineering at UIUC and I've decided a Phd is not right for me a few years ago.  I am curious and want to be a life long learner. I will explore the basis pursuit later, but for now, I'd like to start with something simple...they do want a solution ASAP because right now the quality checks are manually done.
I already ordered a few different microphones. Mind you, not just any mics, but cardioid mics, which hopefully can help filter out ambient noise from the sides...
I remember you mentioned piezo sensors. That's also something I want to explore, but I got no experience with them. I think with piezo I can possibly measure the vibrations directly thru contact and this would make ambient noise irrelevant. As I said before, the production line already has a station where a cylinder/actuator will turn on the device by pressing a button, and perform a function check (make sure things are spinning, etc...) The button won't be released until the test is over. I wonder if it's possible to attach a piezo sensor to the head of the actuator to measure the vibration. However, there will be variations to the "press force" due to variations in placements so I wonder if this will ruin my results.
Just want to try multiple solutions in parallel.
Thanks
Offline rhb
« Reply #44 on: January 24, 2019, 01:20:27 pm »
Getting a  PhD is expensive and unless you have to have the union card not worth while.  I only went back because I had *no* training in seismology at all.  I'd been hired into a job because I had a degree in geology and had taken Diff EQ.  But I thought DSP was super cool and I wanted better than I could do on my own with a stack of books.  When I was hired I was promised several months of training in Tulsa where Amoco had their labs, but I worked for 18 months before I got my only 2 week course.  Meanwhile I had to do the stuff we are talking about and more.  The only thing that saved me was my boss had an MSEE and I had a ham license.  He had come from the labs where he wrote a lot of the DSP codes.  So he could translate geophysics speak into radio speak.  I also knew optics very well and so all my knowledge of the wave equation was very important.
The thing that *is* important about the PhD is acquiring the ability to master a subject for which you have no prior training.  I'm immensely proud of having been able to learn sparse L1 pursuits on my own.  I won't claim to have mastered it because I've not found anyone to test my knowledge against except at a fairly superficial level.  But I do understand it well enough to know that most of the 3000 pages I read are irrelevant to actually applying it.  Most of it is just the logical proof that it works and why.  There is a similar amount of verbiage that was developed to prove that the Fourier transform worked.  As with Heaviside's work, it took the mathematicians a lot of time to develop the logical justification.
Get a couple of these to play with (just in case you break one):
https://www.stewmac.com/Pickups_and_Electronics/Pickups/Violin_Pickups/Schatten_Soundboard_Transducer.html
They are very fragile, so epoxy them to a thin,  ceramic disk magnet the same diameter or slightly larger.  The neodymium magnets would be too strong.  The construction is a thin brass sheet with a pizeo sensor bonded to it and foam to reduce feedback on the top.
One possibility would be to remove the foam and cast an epoxy case with an eyelet.  An actuator could lower the  unit on a string until the magnet grabbed.  Leave the string slack while running the test and then pull it away.
They are made as light as possible so they don't dampen the guitar top.  That doesn't matter in your case.    That is specific to the application on an acoustic guitar.  There are sensors with broader response, but the  prices start going up quickly.  These are cheap enough to play with.
I glued a small spruce disk to the sensor for reinforcement per factory instructions.  They supply butyl tape to attach them and if you try to move one without the spruce reinforcement it will break.
The first photo shows the experimental setup.  I took a scrap tweeter with a busted cone, stripped off the remains and glued a spruce disk to the end of the cone.  Then I swept it with my 33622A from 20 Hz to 20 KHz.  The first scope shot shows the input and the output over the full range and the 2nd up to about 8  KHz.  The amplitude variation of the input is presumably just mismatch between the 33622A and the inductive load. As the reactance rises, the voltage differential across the terminals should go up.  At the time I didn't realize that the 33622A had a high impedance output option so this was a 50 ohm source resistance and the apparent ramp is just the voltage divider effect of the load.
One of the applications of sparse L1 pursuits is "blind source separation".  Or in simple terms, with a few microphones scattered around a crowded cocktail party, isolate any speaker in the room. It's all a question of setting up the proper A matrix for the problem.  I mention that because with a pair of microphones there is a potential to diagnose the exact fault location and thus speed up the rework and collect SPC data.
A box made up with sides in the form of drywall - soft foam - acoustic tile with the drywall on the outside and doors at each end that ran in rails vertically would reduce ambient noise a lot and be very amenable to full automation on a fast moving assembly line.
Clearly what is needed is a "good enough" solution ASAP.  You're already very close to that.  The major hurdle of the fundamental mathematics is done.  So now it's a question of engineering an implementation which meshes well with the production process.  Edison demonstrated how you do that.  You try a lot of possible solutions to a problem.
Have fun and show me some pictures.
Offline rhb
« Reply #45 on: January 26, 2019, 10:51:43 pm »
1) is required.  The others are optional.  But to use them you need to have examples of bad assemblies. So you have to do 1) first to use either.  The best way to discover anomalies is for a human to look at the data and mark them.  The computer can take it from there with ease after a little programming.
It's really worth implementing SVD-KL and basis pursuit and comparing the results.  This is especially true with noisy data. I'm quite confident that the improvement in accuracy and resolution from step to step will be dramatic.
« Reply #46 on: January 29, 2019, 01:50:46 pm »
Thanks.
I'm sure even after I implement that, they will ask me to prove that it is doing what it should. For example, they might wonder if the "microphone is calibrated." What can I do to prove to them that the system is robust?
Are there any good samples of sound with known frequency that I can demonstrate that the FFT is outputting the right result. (I tested already on Youtube videos of sounds but they might want to be more rigorous than that...)
Also, the magnitudes of the FFT depends on sound card, the format of the data, and I guess also the microphone used. Is there even a way to calibrate all that and does it even make sense to do so? Because I can totally imagine they want to know where those magnitude numbers come from.
Thanks
Offline rhb
« Reply #47 on: January 29, 2019, 08:53:25 pm »
 I posted the algebra for sound card errors previously.   Correcting the sound card errors is more exercise in gratuitous accuracy than substantive.  Mostly good for impressing management that you've been very  thorough,  But you might find some real surprises.
Calibrating microphones is expensive and difficult.  Also probably not really needed. To "normalize" the microphones, make a soundproof box and use a spark pug as the source.  Traditional reference was lead shot poured onto a sheet of steel.  Record with each mike in all positions.  Then the math is a simple variant of the card algebra.
BTW Any acoustical enclosure should avoid having any flat or parallel surfaces.  Moisten 1/4" gypsum board to make it flexible and apply 2 layers with the seams at 90.  This is to prevent resonance between the walls from saturating the pickup.
The canonical tests for an FFT are a pure real sequence of ones. The transform is a spike at T0.  The corollary is unit spikes at  T0. TN/2 and Tn.  This should all have unit modulus and the phase angle should go from zero t0 two Pi.  Any deviation needs to be investigated.  These test for an "off by one" in the array indexing of the FFT which is by far the most common error.  The other test is to do the opposite.
The addition in the transform leads to the scaling issue.  I like 1/sqrt(N)  as that means the magnitude of the values stays the same.  There are 6 permutations off the FFT, three scalings and the sign of the exponent.  All are in use by some workers, so you have to watch out for that.
My professional work has always been the opposite.  My job has been to find the anomaly.  That's well defined physically,   However, the noise is another matter.  The best seismic  processors can recover clear signal from data which are so noisy that there is no signal visible at all.
First reference is the masterpiece of classical Wiener-Shannon-Nyquist analysis.  There is a detailed an explanation of everything you want to do there.  So I can explain things simply by saying read section n.p. I started using this 30 years ago in the 2nd edition.  I have pretty much all the DSP classic texts.  It's 10-12 ft of shelving going back to the original publications by Wiener and Shannon.  None of them compare in terms of breadth of coverage of issues of real world importance as B&P.  Alan Piersol passed away, so the 4th is the last edition.  B&P summarizes the mathematics from Fourier in 1820 to Wiener et al in 1940 with detailed derivations for common practical cases. So if you can read the math you can write the code.  There are caveats though as with everything.  Read closely and check the citations.
There is a *lot* of mathematics to learn to implement your use case properly.  This is the first step which must be mastered.  Much of it should be familiar to varying degrees with varying terminology.
Random Data
Bendat & Piersol
4th ed
The 2nd book is Mallat.  It's an essential bridge into the mathematics of modern DSP.  I had it for years in  a couple of editions, but only used it as a reference,  I never read it through. Just looked at the pictures which are very cool.  Foucart & Rauhut made me realize I needed to fill a gap in my knowledge so I read Mallat which resolved the matter.   For years I just used the back part of Mallat and skipped the wavelet discussion.  But wavelet mathematics are important to sparse L1 pursuits in general.
Stephane Mallat
3rd ed
The discussion in Mallat of sparse L1 pursuits is quite adequate for actual practice in a wide range of applications. As it is 10 years old, a new edition should be out soon.
The next thing to be done is collect data on motors, good and bad.  As current screening is manual, put up a waterfall display of the the last N tests for the manual tester to classify as good or bad. Put that monitor in portrait mode.  Also present mean, median, mode and standard deviation A(f) plots on a landscape oriented monitor.  Record all the data and then start running analyses per B&P.  But involve the current testers and the rework staff.  The latter  should repeat the test in a quieter setting, rework the motor noting what was done. and record the motor after rework.
That data is what validates the process.  The people who have been doing it say it works.  Move them to the another bottleneck and repeat.  It's important that success bring them better jobs.
For a test to be useful it needs to last for several rotations of the slowest shaft.  Testing for shorter periods just means some things are not tested.
It's important to note that all the gear work driven by the motor has a harmonic or sub-harmonic relationship to the motor speed.  A good assembly will have a tone at the shaft speed and that times the number of teeth on each gear spinning at that speed.  Other patterns present will indicate the presence of a variation in the gear contact.
FWIW  So far as I can tell sparse L1 pursuits are at the heart of "deep learning" which in turn is just "neural nets" which made the great innovation of  solving an unknown equation the program picked out, done over.  You just hope it has something to do with what you wanted.   What can I say?  I've been to a lot of dog and pony shows.
Offline rhb
« Reply #48 on: February 10, 2019, 12:30:58 am »
I've been contemplating the problem. Both SVD-KL and sparse L1 pursuits require models of good and bad devices.  Those are easy to accumulate over time, but what to do to start?
Get some golden samples of good gearmotors,  count the teeth on all the shafts so you know what multiples of the shaft rotations there will be spectral peaks, make a long recording so that you can average 10,000 FFTs.  Do this in a quiet area and identify all the spectral peaks.
In the line setting, record the ambient noise, run the motor and record it and the noise.  Difference the two recordings and then examine  the residual difference  from the reference recording.
You need to make sure the recordings have multiple full revolutions of all shafts so that all the teeth get checked.
My general thinking is that if you make several ambient noise recordings with gearmotor recordings in between, defective units should be apparent from looking at the residual of the gearmotor - ambient noise - golden reference  averaged spectra. and that simply summing the residual would give you a good initial pass/fail.  In any case, rework should have a well isolated sound chamber to record motors before and after rework to collect the data for more sophisticated models.  You might well find that there are only a few bad unit spectra.
