Author Topic: sourcing small power transformers  (Read 1945 times)
Offline brybotTopic starter
« on: October 29, 2018, 09:12:46 pm »
Hello all, I'm new to the forums, but I've been watching Dave's videos for quite some time.
Anyway, I have an LED aquarium light fixture that I am modifying to add a dimming fixture. It draws 20W and uses two transformers capable of passing that power to the LEDs. The first transformer is 120VAC to 120VAC, which I assume is for isolation, but I'd love to know more if anyone has ideas. The voltage is rectified and fed into a constant current LED driver that generates it's own low voltage power rail, and switches the rectified voltage through an additional transformer with a feedback coil to power the LEDs.
Both of these transformers are capable of passing at least 20VA through them. And they are both tiny, on the order of 2-3 CM^3 in volume.
I've searched and searched, but I cannot find anything similar on Digi-Key, Mouser, or other suppliers. The power transformers I find there are all 500g, and 10CM^3 or larger for that kind of power. Does anyone know where I can find a small transformer off the shelf? Thanks!
Offline Giaime
Re: sourcing small power transformers
« Reply #1 on: October 30, 2018, 07:43:28 am »
I might be mistaken, but from your description it seems that you have a switching power supply and you're trying to think in terms of 50Hz transformers.
Could you post a picture of the electronics of this light fixture?
« Reply #2 on: October 30, 2018, 10:59:05 pm »
I'm on 60 Hz here ;). Anyway, the first transformer is definitely 120 Vac, 60 Hz and 1:1. The second transformer is similar in size, however I am not sure of it's turn ratio. I believe it's operating at a switching frequency in the many hundreds of kHz or low single MHz, but I'll have to check the datasheet again. I'll post the circuit and a picture soon.
Offline langwadt
« Reply #3 on: October 30, 2018, 11:22:22 pm »
there is no way a 20W 60Hz transformers is that small, as you have noticed they are all similar and much bigger, that is just physics. It is either switchmode or  just a filter
« Reply #4 on: October 30, 2018, 11:34:56 pm »
Ah, yes you're right. The first "transformer" is a line filter, probably for EMC since there is a switcher on the other side. The second is a SMPS transformer, and indeed is operating at greater than 60 Hz.
Thanks! That's what I needed to know.
« Reply #5 on: October 31, 2018, 12:02:22 am »
Definitely a filter of some kind. Looking at the underside, I can see that it's not even logically connected as a transformer would be. Photo attached.
Offline drussell
  • Hardcore Geek
« Reply #6 on: October 31, 2018, 12:17:11 am »
That appears to just be a power filter with a common-mode, two winding choke, set up in a pi arrangement...
Capacitor - choke - capacitor
Offline ArthurDent
« Reply #7 on: October 31, 2018, 01:08:23 am »
Definitely a power line filter. Here is a photo of a slightly different one.
« Reply #8 on: October 31, 2018, 07:04:24 pm »
Here's a datasheet that shows the whole circuit, including the input line filter. The actual IC's datasheet doesn't show that. The circuit I have is also set up for input side feedback instead of output side like this one, but otherwise they are functionally identical.
https://www.power.com/sites/default/files/product-docs/linkswitch-ph_family_datasheet.pdf
Offline Ordinaryman1971
« Reply #9 on: November 01, 2018, 07:17:33 pm »
So.... do you want to source bigger line filters just like the one you show there... not sure what do you want to do.
I have 6 of bigger line filters in the same arrangement, is six enough?
« Reply #10 on: November 01, 2018, 08:04:24 pm »
No need to source anything anymore. I was mistaking the line filter for a tiny transformer which I was unable to find. Problem solved!
Offline Richard Crowley
  • KJ7YLK
« Reply #11 on: November 01, 2018, 09:53:04 pm »
If you just want to add dimming to your existing LED illumination setup, you could simply use something like the standalone LED dimmer boxes like:
http://www.mpja.com/LED-Strip-Dimmer-12-24VDC/productinfo/32760+MI
https://www.allelectronics.com/item/dmr-8/12-24-vdc-8a-dimmer-for-led-strips/1.html
They appear to be the same generic Chinese product.  Although MPJA is selling at a much more sensible price (IMHO).
They will operate on 12V just fine.  The "24V" rating is simply the maximum voltage.
« Last Edit: November 01, 2018, 09:55:54 pm by Richard Crowley »
« Reply #12 on: November 01, 2018, 11:18:57 pm »
Thanks for the tip. Unfortunately, these LEDs are running at 75V. I'll probably just change the feedback resistor in the existing circuit to set the current. The datasheet I posted is not quite the same part. The one I have doesn't support triac dimming.
