I've recently attempted to split apart some 36V 18650 packs used in power tools. Yep, it is dangerous, no matter the precautions you take. A few sparks, however, are not a problem (as noted before) .. BUT the nickel welded plate is NOT easy to remove, and I have all the fancy tools. In the end I gave up, as I could see the attempt doing physical damage to the cells. They did a damn good assembly of the 20x cells. Note: using a fine blade dremel to cut up the plates didn't look safe. Good luck.
I've had better luck with Tesla packs
