ok it can be done by hand but it only tells you what the gain should be as opposed to if the op amp is capable of doing it,
C2 at 300Khz would have an impedance of 5305 ohms assuming almost no ESR
C3 at 300Khz would have 5.305 ohms,
And i have no idea how to even begin on the source impendance of a pin diode, so lets just assume its a nice low impendance voltage source,
so R1 in this case would be 5.3 ohms,
R2 would be 5300 ohms (4 mega ohm resistance contributes almost nothing at this frequency)
so your gain is set at 1000 at 300Khz, which is well past what your op amp is capable of at this frequency,
The bode plot is helpful here as you can play with values to help reduce your gain to more sane figures, obviously if the diode has a high source Independence the gain dramatically drops, and lowering the value of its AC coupling cap would reduce the gain aswell,
now if we where to take 120hz for an incandescant bulb your gain is ,
R1 = 13262 ohms
R2 = 13262911 ohms in parrellel with 4 Meg... so = 3.07 Meg
so your gain is 232 even at this low frequency...
